Proton in a uniform electric field
A proton projected into a uniform electric field of E = (-5.80 × 10^5) N/C travels 6.50 cm before coming to rest. The initial velocity (Vi) was calculated using the relationship Vi = (5.556 × 10^13 m/s²)(4.8 × 10^-8 s), yielding a value of 2,666,880 m/s. The discussion highlighted the importance of correctly interpreting the direction of acceleration and the electric field, as well as the need to integrate acceleration to find velocity and position. Misunderstandings regarding the speed of light and the units involved were also clarified.
  • Understanding of electric fields and forces (Coulomb's Law)
  • Knowledge of kinematics and integration in physics
  • Familiarity with the concepts of acceleration and velocity
  • Basic understanding of the relationship between speed, distance, and time
  • Study the derivation of kinematic equations from basic principles
  • Learn about the effects of electric fields on charged particles
  • Explore the concept of relativistic speeds and the speed of light
  • Investigate the integration of motion equations in classical mechanics
Students studying physics, particularly those focusing on electromagnetism and kinematics, as well as educators seeking to clarify concepts related to motion in electric fields.
Feodalherren
A proton is projected in the positive x direction into a region of uniform electric field E = (-5.80 ✕ 10^5) N/C at t = 0. The proton travels 6.50 cm as it comes to rest.
Find the initial velocity and the time it takes for the proton to stop.
The charge of the proton multiplied by the electric field must equal the mass of the proton times the acceleration
qE=ma
hence
a= (-5.556x10^13)
Constant accelecration, integrate with respect to time to get velocity
V= Vi - 5.556x10^13 t
X= 0 + Vi(t) - 2.2778 t^2
Since initial position = 0.
Using the position function to find the time it takes to stop:
.065m = (5.556x10^13)t^2 - (2.2778x10^13)t^2
solving for t, t= 4.8x10^-8 s
Plugging this back to the velocity equation where at t= 4.8x10^-8 s the final velocity = 0 therefore:
Vi=(5.556x10^13 (m/s^2))(4.8x10^-8 s)
Clearly not right, it's faster than the SOL.
Where am I going wrong?
ps. I don't like to memorize stuff so please don't refer me to the kinematic equations. I prefer to derive them by myself.
You need to solve ##v dv = a dx## assuming that ##v = v_i## at ##x = x_0 = 0##.
Or just use ##v_f^2 = v_i^2 + 2a \Delta x## to save some time.
Also that acceleration should be positive I think.
That's exactly what I did? It doesn't seem to be working. I missed something along the way.
Acceleration can't be positive since it's slowing down and moving in the positive x-direction.
Ahh so the electric field is in the ##(- \hat i)## direction.
You seem to be solving ##a = \frac{dv}{dt}##.
Well yes, but only as an initial step. Once I have that I integrate once more to solve for the position function. I can't see anything wrong with it :/.
You can find a relationship between velocity and position because you have the constant acceleration.$$v dv = a dx$$
$$\int_{v_i}^{0} v dv = \int_{0}^{0.065} a dx$$
This let's you solve for the initial velocity. The time taken can now be found from ##a = \frac{dv}{dt}##, or simply use ##v_f = v_i + at##.
But that's exactly what I did...
Look at the integral limits carefully and ask yourself where you went wrong.
I honestly have no clue. This is how I did all of my mechanics in Physics I. I never bothered to remember the kinematic equations as just integrating / taking derivatives worked for everything. I'm missing something fundamental.
Why can't I just integrate from acceleration to velocity to position?
Everything looks correct to me too, I'm not sure then.
What numerical value do you get for Vi? And what is the speed of light? :smile:
ehild
Vi≈3*106
Vi=(5.556x10^13 (m/s^2))(4.8x10^-8 s)= 2,666,880 m/s
... my bad I thought the SOL was about 3 x 10^6 m/s but that's km/s.
Thanks ehild.
Thanks ehild.
No. So what is the SOL? You need to know the magnitude...
3x10^5 km/s = 3x10^8 m/s
ehild
Don't worry about it, I solved it. Thanks again :).
9K
