Prove that two definite integrals are equal
The discussion revolves around proving the equality of two definite integrals involving exponential and polynomial functions. The original poster attempts a substitution method, specifically t=e^t, but struggles with the process. Participants suggest using Riemann sums to demonstrate the equality of the integrals, emphasizing the need to write out these sums and show convergence. However, they caution that manipulating Riemann sums can be complex, especially with non-polynomial functions. Overall, the conversation highlights various approaches to tackle the problem while acknowledging the challenges involved.
Char. Limit
I want to prove the following statement:
\int_0^{ln(2)} \sqrt{e^{2t} + 4 e^{4t} + 9 e^{6t}} dt = \int_1^2 \sqrt{1 + 4 t^2 + 9 t^4} dt
To be honest, I'm not sure how to do this. I tried a substitution t=e^t for the second integral, but it didn't really go all that well. How do you do this, assuming that direct calculation is not allowed?
Let e^t = x.
Then e^t*dt = dx,
When t = 0, x = 1 and when t = ln(2), x = 2.
Substitute these values in the given integration.
Then replace x by t, because the definite integration does not depend on the variables whether it is x or t or any other.
Factor out e^{2t} of the first integral and make t= e^t and change the bounds of integration.
I seem to remember if you have two Riemann sums R1 and R2 if they converge to the same point then they are equal. Could this be used here?
It's less confusing to use a different variable; say, u = e^t.
A better approach is to follow the advice given by rl.bhat and ╔(σ_σ)╝.
Why is that? Cause if the Riemann sums Converge to the same number then integrals are equal aren't they? Maybe I'm just a silly girl.
First of all you have to write out the riemann sums and show it converges to something and write out down the something.
Then you have to prove the two riemann sums are equal.
Well then I wasn't far of was I ? ;)
Well your suggestion was not "wrong". However, it will not be helpful to the OP as the technicality involving your suggestion require a lot of work. And remember the riemann sum ,by definition, is not something you can easily manipulate. When you have functions that are not polynomials , integrating from the definition becomes non trivial even for relatively "simple" functions.
How about you try out your suggestion and see if it works out well.:-)
If I do I will properly get an infraction...
You don't have to post it here and even if you do, you would not get an infraction. Just confess if you cannot do it.
I posted something simular last year and got an infraction so. But yes I could do it...
Do it and send it as a private message to me :-).
Perhaps you have some clever tricks that are worth seeing.
If you can solve the differential in my other post, then we have a deal.
If you mean your non linear differential equation then, no. I do not know how to solve it. I haven't taking any courses on non linear differential equations neither am I interested in learning how to do so, atm.
I know my limitations.:-)
yeah it was this one here
https://www.physicsforums.com/showthread.php?t=431007
OKay fair enough..
  • · Replies 105 ·
