Prove Integrable Function Property on [0,1]
  • I
  • Thread starter mathman
In summary, the mean value theorem for integration can be used to prove the statement that ##a\lt \int_0^1f(x)dx \lt b## if ##f(x)## is a continuous function with ##a=inf(f(x))\lt f(x) \lt b=sup(f(x))##. Alternatively, one can use the general version of the mean value theorem with two functions, or write the integral as a limit of Riemann sums.
mathman
572
Let ##f(x)## be an integrable function defined on ##[0,1]## with the following property: ##a=inf(f(x))\lt f(x) \lt b=sup(f(x))##. Prove ##a\lt \int_0^1f(x)dx \lt b##. It is obviously true, but how does one prove it?
Mean value theorem for integration: https://en.wikipedia.org/wiki/Mean_value_theorem#Mean_value_theorems_for_integration
It requires a continuous function ##f(x)##, so one probably has to have a look on the proof. But if ##f## is continuous, we have ##\int_0^1f(x)dx = f(\xi)\cdot (1-0)## with a mean value ##a<f(\xi)<b##.
The general version has two functions: ##g## continuous, and ##f## integrable, and says ##\int_0^1f(x)g(x)dx=g(\xi)\int_0^1f(x)dx##. Maybe one can find an appropriate ##g## and apply this general version.
Alternatively, write the integral as limit of a sequence of Riemann sums. To get the strict inequality, you will have to play with some ##\epsilon##'s though.
FAQ: Prove Integrable Function Property on [0,1]
1. What does it mean for a function to be integrable on the interval [0,1]?
For a function to be integrable on the interval [0,1], it means that the area under the curve of the function on the interval [0,1] can be calculated using a definite integral. This means that the function has a finite value and can be integrated using different mathematical techniques.
2. How can I prove that a function is integrable on the interval [0,1]?
To prove that a function is integrable on the interval [0,1], you can use the Riemann integral definition, which states that a function is integrable if the upper and lower Riemann sums converge to the same value. You can also use other methods such as the Fundamental Theorem of Calculus or the Lebesgue integrability criteria.
3. Can any function be proven to be integrable on the interval [0,1]?
No, not all functions can be proven to be integrable on the interval [0,1]. If a function is discontinuous or unbounded on the interval, it may not be integrable. However, some functions that may seem to be discontinuous or unbounded can still be proven to be integrable using different mathematical techniques.
4. Why is proving the integrable function property important?
Proving the integrable function property is important because it allows us to calculate the area under the curve of a function, which has many real-world applications in fields such as physics, engineering, and economics. It also helps us to understand the behavior of functions and their properties.
5. Are there any practical implications for the integrable function property on the interval [0,1]?
Yes, the integrable function property has many practical implications. For example, it allows us to calculate the work done by a force, the distance traveled by an object, or the total profit of a business over a certain time interval. It also helps us to solve optimization problems and make predictions about the behavior of systems.
