Prove: |x+y|<|xy+1| for |x|,|y|<1
The discussion revolves around proving the inequality |x+y| < |xy+1| for real numbers x and y constrained by |x| < 1 and |y| < 1. Participants are exploring the implications of these constraints in the context of absolute values and inequalities.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss different cases based on the signs of x and y, suggesting that dividing the problem into cases may help in proving the inequality. Some participants question the necessity of listing all cases, while others note the symmetry in the problem. There are attempts to manipulate the inequality by considering specific conditions and relationships between x and y.
The discussion is active with various approaches being explored. Some participants have shared their reasoning and attempts at proving the inequality, while others have offered guidance on how to approach the problem. There is no explicit consensus on a single method or solution yet.
Participants are working under the constraints of the problem, specifically the conditions |x| < 1 and |y| < 1, which are central to the discussion. There is also mention of the challenge in handling absolute values and inequalities.
liluiass
X and Y 2 real numbers / |x| <1 and |y|<1
Prove that |x+y|<|xy+1|
|x+y|<2
I couldn't prove that |xy+1| >2
And couldn't find a way to solve the problem
Please help
That's good because
(1) It's not true
(2) It's not at all what you have been asked to prove.
|x+y|<2
Please help
Note that you have, essentially, three cases:
1) ##x, y \ge 0##
2) ##x, y \le 0##
3) ##x \le 0, \ y \ge 0##
You could try those cases separately and see what you can do.
Since, by definition, |x| = x when x ≥ 0 and |x| = -x when x < 0, a general method for "removing" absolute values is to divide each instance of an absolute value into two cases. Perhaps you can find a way to divide the relation you are trying to prove into such different cases? For instance, how must x and y relate to each other if you are to "remove" the absolute value on |x+y| ?
Edit: I type way too slow :rolleyes:
1) ##x, y \ge 0##
2) ##x, y \le 0##
And this one?
4) ##x \ge 0, \ y \le 0##?
Mark44 said:
And this one?
It's symmetric in ##x## and ##y##. That's just the same as case 3).
You're thinking one step ahead and realizing that it works out that way, but for slow people like me it's beneficial to state ALL the cases up front so I think Mark's statement is appropriate.
I MIGHT have thought to make one of the conditions just "x and y have different signs" and then it does become just one condition.
I MIGHT have thought to make one of the conditions just "x and y have different signs" in and then it does become just one condition.
That would be fair enough if I hadn't said "essentially". Formally, I would have said wlog (without loss of generality).
A fair point. I hadn't notice that.
I think I got it?
If x>0 and y>0
Then |x+y |= x+ y and | xy+1|=xy +1
We have to prove that x+y < xy +1
X-1 < xy -y
X-1 < y(x-1) / x-1<0
1>y which is true tgeb x+y <xy+1
--if x and y are negative
|x+y |= -x-y and xy +1>0 then |xy+1 |=xy +1
Let us prove again thet -x-y <xy +1
-x-xy<1+y
-x(1+y)< 1+y / -1<y<0 => y+1>0
-x<1< = > x>-1 which is true .
----case 3 if xis positif and y is negatif
0<x<1 , -1<y<0
-1<x+y<1 ,1+ xy<1
If x+y >0
We have to prove : x+y < xy +1
X-1< y(x-1) /x-1 <0
1> y true.
If x++y <0 ..we have to prove that -x-y <xy +1 ..
-x(1+y) <1+y ../ 1+y >0
So -x<1
X>-1 which is true
liluiass said:
I think I got it?
Probably - I haven't checked the details - but there is a much easier way.
Note that |a|>|b| if and only if a2>b2.
Yes I know i tried it out first and didn't knowif its alright to use the same method bec I couldn't remember how inequalities work at this point
Thats said it is shorter probably if I didn't make any mistake...I though I absolutely did
Would you mind posting that attempt?
There being no response, I'll post my full solution.
|x|<1, |y|<1
x2<1, y2<1
(1-x2)(1-y2)>0
1+x2y2>x2+y2
1+2xy+x2y2>x2+2xy+y2
(1+xy)2>(x+y)2
|1+xy|>|x+y|
Note that |x|>1, |y|>1 leads to the same result.
  • · Replies 17 ·
  • · Replies 17 ·
