Proving a linear transform is diagonalizable
  • Thread starter Thread starter dargar
    Linear Transform
3 replies · 4K views
dargar
Let U be the R-vector space consisting of all polynomials of degree at most n with
coefficients that are real.
The Derivative Map
F : U [tex]\rightarrow[/tex] U
f(x) [tex]\rightarrow[/tex] f'(x)
Is the derivative function F diagonalizable?
My instinct says yes but I'm not too sure why. Am I right in saying that eigenvalues are invariant after a linear transform. I'm pretty sure that before the function is applied you can have a matrix that has n+1 distinct eignenvalues but not sure if this is the right lines or if it is how to set about writing it down in a proof format.
Any help would be great thanks !
Can you be more precise in what you mean? Eigenvalues of what? What linear transform?
The linear transform is differentiation function.
The eigenvalues I'm not so sure of , the main reason I say it is because in my notes it seems to be the only thing remotely to do with this question.
In the following deffinitions I have , I assume he means A is the vector space you start with
Let A be an (nxn) matrix, A is diagonalisable by similarity transform if and only if there is a basis for R^n consisting of entirely eigenvectors for A.
and
If A is diagonisible then
the sum of the distinct eigenvalues for dimension of the eigenspace = n
Oh and I also know that eigenvalues are similarity invariant but their eigenvector aren't (altho they have a 1 to 1 correspondance after the function is applied)
Sorry I'm pretty confused at how to go about this, so I'm sorry if it doesn't make sense
No, he meant what he said: A is an nxn matrix. Diagonalizability is not a property of vector spaces; it is a property of matrices (and of linear transformations).
(This n, of course, does not necessarily have anything to do with the n in your original problem)
This doesn't make sense. I know the theorem you're trying to state, but the idea you have in your head doesn't make sense.
If a matrix is diagonalizable, then:
It have a set of (distinct) eigenvalues.
Each of those eigenvalues has a corresponding eigenspace.
Each of those eigenspaces has a dimension.
The sum of all of those dimensions is n.
It's often useful to start with special cases. Try working through the n=0 case. Then the n=1 case. Mabe even the n=2 case. Only then worry about the general case.
