Proving an Inequality: A Scientific Approach
22 replies · 3K views
AlexOliya
Member warned about posting with no effort shown
With the regards to posting such a incomplete equation, I will soon put in the updated one
Thank you
visual graph... didn't help
pasmith said:
What is the range of integration?
Our teacher did not write any range :/
PF Rules require you to make some efforts and to show your work before seeking help (or, more precisely, they do not permit us to help until you have shown your work).
Anyway, the question is incomplete: what are the integration limits?
Note added in edit: I see that the latter question has already been posed to you, but appeared on my screen only after I pressed the 'enter' key.
Certainly I didn't tackle the equation without effort but I didn't want to send my rather nonsensical and messy attempts .
I replied the last question you asked above
If you do not show your "nonsensical and messy" attempts, how are we supposed to know where you are having trouble? We need to see what you have done, wrong or not! (BTW: I edited my previous post, which dealt with your response about integration limits).
Okay haha!
Well I looked for the first function which turned out a complex function. and I graphed the function using the Algeo app but still didn't help. I tried setting the limits pi fourth to half pi but still is risky
Our teacher suggested a guide tip for using the Mean value theorem... But it doesn't have a range !
AlexOliya said:
Okay haha!
Those limits cannot possibly work, as they would involve values of ##x## for which ##\sin^{-1} (x)## is either undefined, or not real. (I am assuming you mean the inverse sine function, rather than the reciprocal ##1/\sin x##.)
micromass said:
How can you even begin to solve this if you don't know the integration limits? This is crucial information
rather should I storm upon the teacher for this crucial mistake?
definitely I mean the inverse sine function. Well it has come to a conclusion that limits are needed and essential
micromass said:
Yes.
Thanks for all the help
If ##f(x) = \arcsin(x)/(1+x^8)##, the possible case ##\int_{-1}^1 f(x) \, dx## is easy to compute explicitly (with almost no work), and the left-hand inequality is FALSE but the right-hand one is (trivially) true. Thus, if the integration limits are -1 and +1, only one of the two inequalities is true.
The other obvious possibility, ##\int_0^1 f(x) \, dx##, takes more work; both bounds are true, as shown by numerical evaluation of the integral. However, proving it "analytically" is a challenge.
Ray Vickson said:
If ##f(x) = \arcsin(x)/(1+x^8)##, the possible case ##\int_{-1}^1 f(x) \, dx## is easy to compute explicity (with almost no work), and the inequality is (trivially) true in that case. The other obvious possibility, ##\int_0^1 f(x) \, dx##, takes more work; the lower bound is easy to verify (again, with essentially no work), while the upper bound is true (as seen numerically), but is not at all obvious anymore. Why don't you see if you can prove ##\int_0^1 f(x) \, dx \leq \frac{\pi}{2} - 1##, without performing a numerical evaluation of the integral?
I did try this today in fact. Tomorrow I will see my Math teacher and definitely will ask why she made this mistake and see what she had in mind!
Thank you for your help dear friend
Please note that I made an error in post #14 (due to a typo). I have edited that post, and you should look at it again.
I come updated.
The limits are 0 to positive 1
AlexOliya said:
The integration limit is 0 to +1
Ray Vickson said:
Works for the lower bound as well.
Many Many thanks! Helped a lot!
