Proving Equivalence of Subspaces: x+y+z=0
  • Thread starter Thread starter Dafe
    Span Subspace
The discussion centers on proving that if vectors x, y, and z satisfy the equation x+y+z=0, then the subspace spanned by x and y is equivalent to the subspace spanned by y and z. The participants establish that the linear dependence of the vectors implies they can only span subspaces of dimensions 0, 1, or 2. Through a series of linear combinations, they demonstrate that any vector in the span of x and y can be expressed as a linear combination of y and z, and vice versa, confirming the equivalence of the two subspaces.
  • Understanding of linear dependence and independence of vectors
  • Knowledge of vector spaces and subspaces
  • Familiarity with linear combinations of vectors
  • Basic proficiency in mathematical proofs and reasoning
  • Study the properties of linear combinations in vector spaces
  • Learn about the concepts of span and basis in linear algebra
  • Explore the implications of linear dependence in higher dimensions
  • Investigate the relationship between subspaces and their dimensions
Students studying linear algebra, mathematicians interested in vector spaces, and educators teaching concepts of linear dependence and subspace equivalence.
Dafe
Here's a statement, and I am supposed to show that it holds.
If x,y, and z are vectors such that x+y+z=0, then x and y span the same subspace as y and z.
N/A
If x+y+z=0 it means that the set {x,y,z} of vectors is linearly dependent. Because of this dependence, the vectors cannot span a subspace with dimension greater than 2.
That is, they can span subspaces with dimensions 0,1 and 2.
  • If they span a subspace with dim=0, then x=y=z=0.
  • If they span a subspace with dim=1, then two vectors are negative multiples of each other with the third one being the zero vector.
  • If they span a subspace with dim=2, then one is a linear combination (with -1 as coefficients) of the other two.
In all these cases x and y span the same subspace as y and z.
Any suggestions are greatly appreciated.
Thanks.
I think you are missing the point of the question.
Let v be in the subspace spanned by x and y. Then v= ax+ by for some numbers a and b. But x+ y+ z= 0 so x= -y- z. v= a(-y- z)+ by= (b-a)y+ (-a)z. That is, v is a linear combination of y and z and so is in the span of y and z.
That proves that the subspace spanned by x and y is a subspace of the span of y and z. I will leave it to you to show that the span of y and z is a subspace of the span of x and y.
Let v be in the subspace spanned by y and z, Then v= ...
Ah, I certainly missed the point of the question!
Let v be in the subspace spanned by y and z.
Then v=ay+bz for some numbers a and b.
But x+y+z=0 so z=-x-y.
v=(a-b)y+(-bx), that is, v is a linear combination of y and x and so is in the span of y and x.
This proves that the subpsace spanned by y and z is a subspace of the span of y and x.
We have now proved that the subspace spanned by x and y is the same as the one spanned by y and z.
Thank you!
