Proving Expectations at Infinity in a Paper: Tips and Tricks
The discussion revolves around proving an expectation formula related to the convergence of sums involving random variables as n approaches infinity. The key equation presented is E{(Σ(α^i e^2(n-i-1)))(Σ(α^i e^2(n-i-1)))} = (2α(E(e_∞^2))^2)/((1-α)^2(1+α)) + E(e_∞^4)/(1-α^2). Initially, the poster sought help due to difficulties in deriving this result from a referenced paper. After some exchanges, the poster confirmed that they successfully proved the equation. The discussion highlights the importance of defining variables clearly for effective communication in mathematical proofs.
feryee
While reading a paper, i came across the following Expectations:
Given that the ##E\left\{e^2_{n-i-1}e^2_{n-j-1}\right\}=E\left\{e^2_{n-i-1}\right\}E\left\{e^2_{n-j-1}\right\}## for ##i\neq j##.\\
Then as ##n\rightarrow\infty##
##E\left\{\left(\sum\limits_{i=0}^{n-2}\alpha^i e^2_{n-i-1}\right)\left(\sum\limits_{i=0}^{n-2}\alpha^i e^2_{n-i-1}\right)\right\}=\frac{2\alpha\left(E\left( e_\infty^2\right)\right)^2}{(1-\alpha)^2(1+\alpha)}+\frac{E\left( e_\infty^4\right)}{(1-\alpha^2)}##.
Can you provide me with proof or any hint/help? I tried but couldn't get the same answer.Thanks
Given that the $E\left\{e^2_{n-i-1}e^2_{n-j-1}\right\}=E\left\{e^2_{n-i-1}\right\}E\left\{e^2_{n-j-1}\right\}$ for $i\neq j$.\\
Then as $n\rightarrow\infty$
$E\left\{\left(\sum\limits_{i=0}^{n-2}\alpha^i e^2(n-i-1)\right)\left(\sum\limits_{i=0}^{n-2}\alpha^i e^2(n-i-1)\right)\right\}=\frac{2\alpha\left(E\left( e_\infty^2\right)\right)^2}{(1-\alpha)^2(1+\alpha)}+\frac{E\left( e_\infty^4\right)}{(1-\alpha^2)}$.
Those latex expressions are not displaying on my browser.
PS Is this homework?
No, This is an equation in a paper.(Eq 17 in ''New Steady-state analysis result for variable step-size LMS algorithm with different noise distributions'')
More information is needed. Specifically: define e_k.
Thank you all for your comments. I finally proved it.
I'm taking a look at intuitionistic propositional logic (IPL). Basically it exclude Double Negation Elimination (DNE) from the set of axiom schemas replacing it with Ex falso quodlibet: ⊥ → p for any proposition p (including both atomic and composite propositions). In IPL, for instance, the Law of Excluded Middle (LEM) p ∨ ¬p is no longer a theorem. My question: aside from the logic formal perspective, is IPL supposed to model/address some specific "kind of world" ? Thanks.
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
