Proving the Limit of 2x-2y2/(x2 - y2) Does Not Exist
  • Thread starter Thread starter hover
    Limit
hover
1. Homework Statement
Prove or disprove that the following limit exists
lim x->0 and y->0 of
2x-2y2/(x2 - y2)
2. Homework Equations
0 < ((x-a)2+(y-b)2).5 < delta
|f(x,y)-L| < epsilon
If I take the limit of x to approach 1 of f(x,1) then the limit is equal to 1
If I take the limit of y to approach 1 of f(1,y) then the limit is equal to 2
I can then say that the limit in question DNE. To prove this, can't I just say since there are 2 different L's we will get 2 different \delta 's and because of these 2 \delta 's we will be able to satisfy at least one \delta but not always both?
Does this make sense?
Thanks!
2x-2y2/(x2 - y2)
This isn't (2x-2y2)/(x2 - y2), is it?
|f(x,y)-L| < epsilon
hover said:
Why are you letting x and y approach 1? Your limit is as (x, y) --> (0, 0).
Thanks!
oh crap sorry about that. Yes
(2x-2y2)/(x2 - y2)
Wow I really balled this up. This should be
lim x->1 and y->1 of
(2^x-2y^2)/(x^2 - y^2)
0 < ((x-a)^2+(y-b)^2)^.5 < delta
|f(x,y)-L| < epsilon
3. The Attempt at a Solution
I can then say that the limit in question DNE. To prove this, can't I just say since there are 2 different L's we will get 2 different \delta's and because of these 2 \delta's we will be able to satisfy at least one but not always both?
Thanks!
If you can show that the limit is different for two different paths, then that's enough to say that the limit doesn't exist. You don't need to go on and prove anything more.
Awesome!
Thanks!
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
