Proving Trig Equation: cosx + cos3x +cos5x = sin6x/2sinx
  • Thread starter Thread starter es801
    Proof
The discussion centers on proving the trigonometric equation cosx + cos3x + cos5x = sin6x/2sinx. Participants emphasize the importance of using trigonometric identities, particularly sum/difference and multiple-angle identities, to simplify the equation. There is a suggestion to express both sides in terms of single variables, such as using sin(5x) as sin(4x+x) for expansion. The use of complex numbers and Euler's formula is mentioned, although it's noted that these concepts are not typically covered in general trigonometry. Overall, the focus is on applying identities to facilitate the proof of the equation.
es801
I am having trouble proving the following trigonometric equation:
Any help would be appreciated
You'll need to show us your attempt before we can help you. I assume that you are familiar with the trigonometric identities (particularly, the sum/difference & multiple-angle identities).
Are you familiar with complex numbers and Euler's formula?
ehild
ehild
They don't teach those in general trigonometry. Though that would work (as it usually does).
Since this is in terms of x, I would try to use the identity (sin(x+x))= ... to get the whole thing in terms of single variables. For example sin(5x) is really sin(4x+x) which can expand, and then sin(3x+1) expands out and so on. Then it should be easy to simplify.
Try to write both sides in terms of cos(3x) and cos(x), using the addition rules. (x=3x-2x, 5x=3x+2x, 6x=2*(3x) ).
ehild
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
