Can You Extend the Range of a Proximity RFID Tag?
  • Thread starter Thread starter sims123
    Range Rfid
Extending the range of a proximity RFID tag is challenging, particularly with passive tags, which require close proximity to a reader. Suggestions include building a small micropower transmitter to broadcast the tag information, allowing for remote activation. However, concerns arise about signal clarity and how to differentiate the RFID card's signal from background noise. Using an RFID reader to capture the card's contents is essential for this process. Ultimately, achieving a reliable long-range solution for passive RFID tags may require innovative approaches or technology.
sims123
Hey guys...not sure if this is possible but is there a way to extend the range of a proximity RFID Tag. I'm looking for a way to broadcast the tag information so i don't have to walk up to the reader with a proximity tag. I'm trying to find a way to open my apartment gate by driving up to it instead of rolling down the window and scanning it. Any ideas?
Build a small micropower transmitter that outputs the rfid codes.
How would you be able to pick out the signal from the RFID card?
Use an RFID reader to get the card contents.
Hi,
Is that a passive or an active tag?
t.
its passive
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
