How Do You Modify a Key in a Min-Heap to Maintain Heap Properties?
  • Thread starter gotem3303
  • Tags
    Code
In summary: Just try to figure out how to do it and see if you can optimize later.In summary, the operation HEAP-MODIFY(A, i, k) changes the key in the node i to a new value k and rearranges the elements in a min-heap. The implementation of HEAP-MODIFY should run in O(lgn) time for an n-element min-heap. This can be achieved by considering the properties of a min-heap and using a divide-and-conquer access pattern. The key to solving this problem is understanding what makes A a min-heap. The runtime is not a concern at this point, the main focus should be on finding a solution and optimizing later.
gotem3303
29
Let A be a min-heap. The operation HEAP-MODIFY(A, i, k) changes the key in the node i to a
new value k, then rearranges the elements in a min-heap. Give an implementation of the HEAPMODIFY that runs in O(lgn) time for an n-element min-heap.
Ive been trying to work this one for over a day and can't seem to get it. I am pretty sure there will need to be 2 cases, one where the key has been increased and one where the key has been decreased. This would be determined by comparing the new value to the node with indexes i+1 and i-1. However, that's where I am stuck.
The only solution I've found that would work is if I took the new value and went through a loop that did the following:
  1. Check the node with index i-1, if new value is less then exchange the keys
  2. Same as above, but with index i+1, and if the new value is larger than this one exchange them
  3. Continue this loop until the new key is where it should be
However, I don't know what the RT would be for the above algorithm, but I am guessing O(n)? This would the Psedo Code I came up with
Code:
A[i] = k
if increased
  while A[i+1] < k and i > 1
     exchange A[i], A[i+1]
     i=i+1
else if decreased
  while A[i-1] > k and i < A.length
    exchange A[i], A[i-1]
    i=i-1
You are so in my class.
Guess all the analysis of algorithm newbs are going to forums for answers.
I think you will need to say more about the implementation of your min-heap. The O(lgn) bound assumes a divide-and-conquer access pattern.
The question you have to ask yourself is, what are the properties of a min heap? Is it a binary heap tree? After listing all the properties of the heap tree, I would draw a heap tree out, then randomly insert a number in one of the node, then check to see how I would modify it to make it a heap tree again. After doing that by hand, think about the tree in a one dimensional array. Hopefully that will be some help for you. The important thing is you have to know what makes A a min-heap.
I wouldn't worry about the run time just yet.
This is a good start to your solution, but it does not run in O(lgn) time. In order for this operation to run in O(lgn) time, you will need to use the properties of a min-heap to efficiently rearrange the elements. One way to do this is by using a recursive approach.
Here is a possible solution in pseudo code:
A = k
if A < A[parent(i)]
MIN-HEAPIFY(A, i)
else
MAX-HEAPIFY(A, i)
MIN-HEAPIFY(A, i)
if A < A[parent(i)]
exchange A, A[parent(i)]
MIN-HEAPIFY(A, parent(i))
MAX-HEAPIFY(A, i)
if A > A[parent(i)]
MAX-HEAPIFY(A, parent(i))
In this solution, the MIN-HEAPIFY and MAX-HEAPIFY functions recursively compare the key at index i with its parent and swap them if necessary. This is done until the key reaches its correct position in the heap, which will have a runtime of O(lgn).
Overall, the HEAP-MODIFY function will have a runtime of O(lgn) since it only makes a constant number of calls to MIN-HEAPIFY or MAX-HEAPIFY.
1. What is the purpose of "Pseudo Code for HEAP-HODIFY"?
The purpose of "Pseudo Code for HEAP-HODIFY" is to provide a step-by-step guide on how to implement the heap-hodify algorithm, which is used to maintain the heap property in a heap data structure.
2. What is the heap data structure?
A heap is a specialized tree-based data structure that satisfies the heap property, where the parent node is either greater than or equal to its child nodes. This allows for efficient retrieval of the maximum or minimum element in the heap.
3. What is the heap-hodify algorithm used for?
The heap-hodify algorithm is used to maintain the heap property in a heap data structure. It ensures that the root node of the heap contains the maximum or minimum element, depending on the type of heap. This allows for efficient retrieval of the maximum or minimum element in the heap.
4. How does the heap-hodify algorithm work?
The heap-hodify algorithm works by comparing the root node with its child nodes and swapping them if necessary to maintain the heap property. This process is repeated until the entire heap is in the correct order.
5. Is "Pseudo Code for HEAP-HODIFY" language-specific?
No, "Pseudo Code for HEAP-HODIFY" is not language-specific. It is a generalized algorithm that can be implemented in any programming language to maintain the heap property in a heap data structure.
