Pumping Air Over Wing: Advantages & Disadvantages?
  • Thread starter Thread starter sid_galt
    Air
The discussion revolves around the advantages and disadvantages of pumping air over a wing during flight, particularly focusing on its effects on lift and drag. Participants explore both theoretical implications and practical challenges associated with this concept, including boundary layer control and winglet design.
  • Some participants propose that blowing air over the top surface of a wing could reenergize airflow, potentially reducing turbulence and increasing lift, although the effects of hot air might be negligible.
  • Others argue that pumping air could detach the boundary layer, leading to increased drag and destabilization of the aircraft if the airflow is uneven.
  • Concerns are raised about the practical implementation of air pumping, including the need for complex ducting and pumps, which could reduce space for fuel tanks.
  • Some participants question whether pumping hot or cold air would be effective on low Reynolds number wings, suggesting that it may not provide any advantages.
  • There is mention of existing research on suction through porous wing walls, which can delay boundary layer detachment and decrease drag, contrasting with the idea of blowing air over the wing.
  • Discussion includes a query about the orientation of winglets and the potential effects of having both positive and negative angled winglets on performance.
Participants express a range of views, with some supporting the idea of air pumping for lift enhancement and others contesting its effectiveness and practicality. The discussion remains unresolved, with no consensus on the advantages or disadvantages of the proposed method.
Limitations include the dependence on specific conditions such as airflow uniformity and the Reynolds number, as well as unresolved questions regarding the practical implementation of air pumping systems.
sid_galt
pumping air over wing??
So if hot/cold air is blown over the top surface of a small sized wing inflight which has a medium angle of attack, will it help in the lift or will it be a disadvantage?
I can only think of two things
1) Advantage: It will reenergize the airflow and help in reducing turbulence. Higher speed of wind will decrease pressure and increase lift though temperature of hot air might render the effects of the increased lift negligible.
2) Disadvantage: It might detach the boundary layer and might increase the drag substantially. If the blow speed gets even a little bit uneven, it may destabalize the aircraft considerably. It will result in uneven distribution of lift across the wingspan unless the air is uniformly blown all over the wing. This will result in increased stress.
What do you think?
If it turns out to be a disadvantage, would blowing the air under the wing instead of the top result in increased performance/lift?
Also a question about winglets. Why are winglets oriented with a positive angle and not a negative one? What if one has two winglets with + and - angles? Would that help in performance especially in small aircraft?
The suggestion is not new. However the problem with pumping air through pores in the wing is that large amounts of complex ducting and pumps will be required. Space in the wing normally reserved for fuel tanks will also need to be cut down.
Ducting, energy issues and pumps aside, will the suggestion actually work with either hot or cold air even on low Reynold number wings?
I don't see any advantage, besides I don't understand the advantages you posted. Pumping air will increase turbulence instabilities and drag.
The fact is it has been a lot of research in sucking air through a porous wing wall. The suction of air delays the boundary layer point of detachtment, decreasing drag.
Some turbomachine blades are machined in such a way to have such porous wall.
I was going to mention boundary layer control experiments using vacuums but Clausius beat me to it.
You may want to look at this link:
http://aerodyn.org/Drag/blc.html
It does talk about injection techniques.
  • · Replies 23 ·
