Push Limits: Good Morning Questions
  • Thread starter Thread starter Abukadu
    Limits Push
Abukadu
Good morning :)
I got a couple of question, hope I won't bother you guys too much.. its about function limits.
1)
http://www.upit.ws/uploads/53401353963d7.JPG
what I tried to do was to say that for all delta>x-(7/4) there is 3x/(4x-7)>M
than I tried to work with 3x/(4x-7)>M so that ill get an expression that looks like x-(7/4) but I got stuck trying to get it out of the denominator.
2)
http://www.upit.ws/uploads/6e159c2fa9206.JPG
if to every epsilon>0 there's a x0 so that for all x > x0 exists |f(x) - L| > epsilon.
tried developing the |f(x) - L| > epsilon part but got stuck in: |(2x+7)/(x^2 +3x +1)| < epsilon
3)
for extra credit :) I need to prove (using epsilon and delta) that if a function has a limit (when x->infinity) then its singular, meaning if f(x) [x->infinity]=L and f(x) [x->infinity]=K then L=K !
I know it probably dosent seem like I tried too hard from the attempts to solution I wrote but I wasted quite a few pages on different tries. They just don't seem to get me anywhere so I saved me the trouble of trying to write them in english (not exactly my forte..)
I don't understand exactly what the question is, but I'll assume you want to prove these limits. However, I have only studied limits at a high school level so my answers could be completely off the topic. If so, just disregard my post.
1) I thought this would be obvious. Take the numerator - for x->7/4+, it equals 21/4 (positive). The denominator - it approaches 0 from the positive end. Thus we have a positive number divided by an infinitesimally small positive number. Approaching infinite.
2) Use the result that for lim (x-> infinite) 1/x = 0.
Divide both numerator and denominator by the highest power of x, so we have (1+5/x+8/x^2)/(1+3/x+1/x^2). As x -> infinite, all parts with the variable in the denominator will approach 0. Therefore we end up with 1/1.
3) Sorry I don't understand this.
thanks for trying but your answers are regarded as "intuitive" at this point
Abukadu said:
Good morning :)
1)
You want to show that, given a number M > 0, there exists a small number \delta &gt; 0 such that when 0 &lt; x - 7/4 &lt; \delta, \frac{3x}{4x -7} &gt; M.
Because this is a right-hand limit, you don't need absolute values around x - 7/4.
So let's find delta.
We want \frac{3x}{4x - 7} &gt; M
or, 3x &gt; M(4x - 7)
Since x > 7/4, 4x - 7 > 0, so the direction of the inequality doesn't change.
Now bring all the terms involving x to one side of the inequality, to solve for x.
You should end up with x &lt; \frac{7M}{4M - 3}, so take delta to be the value on the right minus 7/4.
Abukadu said:
2)
3)
Abukadu said:
Good morning :)
1)
2)
You don't have this quite right. For every epsilon > 0 there is a (large) number M so that when x > M, |f(x) - 1| is less than epsilon. I used M here instead of x0, not because x0 is incorrect, but just to convey the idea that M is supposed to represent a large number. I also replaced your L with the limit value, 1.
Here I have used f(x) = \frac{x^2 + 5x + 8}{x^2 +3x +1}. As your work shows, f(x) - 1 = (2x + 7)/(x^2 + 3x + 1).
Work with the inequality: -eps < f(x) - 1 < eps, or 1 - eps < (2x + 7)/(x^2 + 3x + 1) < 1 + eps. Try to break this down so that you have x in the middle of the inequality, and expressions involving epsilon on either end. If you can get there, you can figure out what M has to be.
Abukadu said:
3)
Thanks mark, ill try solving 2 and see if I can get there.
as to 3, I managed to prove it myself :-)
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
