Python [Python] Keeping the session alive
  • Thread starter Thread starter adjacent
    Python
The discussion revolves around a Python script designed to interact with a CAPTCHA system hosted on a local server. The script retrieves a CAPTCHA image from a PHP file, uses Tesseract OCR to extract the text, and then submits this text along with a manually entered number to another PHP file. The expected outcome is a generated HTML table based on the submitted data. However, the script fails to produce the table, likely due to session management issues, as it starts a new session when posting to the second PHP file. A participant suggests that a missing ".txt" extension in the system call might be causing issues with the text file generation, but it's clarified that Tesseract automatically saves the text file. Ultimately, the original poster resolves the issue by encapsulating the requests in a session context, ensuring the session remains consistent throughout the process.
adjacent
I am experimenting with capatcha images. I have a capatcha.php in my local host which will generate an image and that image will be put into the form
Here is my python code to get the image, extract the text in it and send them back to the form. And finally save the resulting form as html.
The form has Two fields, Number and Code. And it will return a table of things.
But it's not working. The html saved by python does not have the table. I don't see any problem with the code :confused:
Code:
import os
import requests
p = requests.session()
q = p.get('[PLAIN]http://localhost/Test/Capatcha.php')[/PLAIN]
with open('data/a.png', 'wb') as f:
    f.write(q.content)
os.system("tesseract C:\\Users\\Me\\Desktop\\Test\\data\\a.png C:\\Users\\Me\\Desktop\\Test\\data\\a")
with open("data\\a.txt") as cap:
    capData = cap.read()
print("Capatcha line:"+capData)
num = input("Please enter the number :")
payload = {
    'Code': capData,
    'q': num
url = "[PLAIN]http://localhost/Test/index.php"[/PLAIN]
r = p.post(url, data=payload)
with open("data\\log.html", "w") as file:
    log = file.write(r.text)
Technology news on Phys.org
I have not idea what you are talking about; but, is there, by any chance, a missing extension ".txt" in the system call? That might be the reason why your a.txt file does not have what is supposed to?
Why? Can you tell me what you didn't understand?
I have a folder in my localhost which is called 'Test'. In that folder, I have two php files: Capatcha.php and Index.php. I also have a folder called 'data' in the 'test' folder.
What the capatcha.php does is, start a session and generate a random image with numbers.
The index.php has two input fields one is called 'Code' and other is called 'q'.
What I am trying to do is, download the capatcha image from the capatcha.php and get the text in the capatcha image with an OCR engine(Tesseract).
The code in os.system() will save the resulting text in a text file called data.txt. And I will save that text in a variable called 'capData'
Then the python program will ask for a number which I will enter manually. It will be saved in a variable called 'num'
Then the python program will connect to index.php and enter the values of 'q' which will be the value for 'num' ,and 'Code' which will be the value for 'capData'.
Then If the 'Code' matches the one in the capatcha image, the php file will generate a table containing a name and the number.
My problem is that it does not generate the table and I think the reason is because when the python program connects the index.php, it is not in the capatcha session. It started a new session.
So My question is how to keep the session alive. I don't see any problem in my code above. However, it does not work.
'Tesseract' (OCR engine) will automatically save it as a text file.
Here is a php code which does the same thing I am trying to do.
Code:
<?php
include("simple_html_dom.php");
$tmp_fname = tempnam("data", "COOKIE");
$header[0] = "Accept: text/xml,application/xml,application/xhtml+xml,";
$header[0] .= "text/html;q=0.9,text/plain;q=0.8,image/png,*/*;q=0.5";
$header[] = "Cache-Control: max-age=0";
$header[] = "Connection: keep-alive";
$header[] = "Keep-Alive: 300";
$header[] = "Accept-Charset: ISO-8859-1,utf-8;q=0.7,*;q=0.7";
$header[] = "Accept-Language: en-us,en;q=0.5";
$header[] = "Pragma: ";
$curl_handle = curl_init("[PLAIN]http://localhost/Test/Capatcha.php");[/PLAIN]
curl_setopt($curl_handle, CURLOPT_USERAGENT, 'Mozilla/5.0 (Windows NT 6.1; rv:31.0) Gecko/20100101 Firefox/31.0');
curl_setopt($curl_handle, CURLOPT_HTTPHEADER, $header);
curl_setopt($curl_handle, CURLOPT_REFERER, '[PLAIN]http://localhost/');[/PLAIN] [/PLAIN]
curl_setopt($curl_handle, CURLOPT_COOKIEJAR, $tmp_fname);
curl_setopt($curl_handle, CURLOPT_COOKIEFILE, $tmp_fname);
curl_setopt($curl_handle, CURLOPT_RETURNTRANSFER, true);
$output = curl_exec($curl_handle);
file_put_contents("data/a.png", $output);
$path = "C:/xampp/htdocs/edi/";
try
   exec($path."Tesseract-OCR/tesseract.exe ".$path."data/a.png ".$path."data/a", $msg);
   $capture = trim(file_get_contents("data/a.txt"));
   echo $capture;
   unlink("data/a.txt");
catch (Exception $e)
   echo $e;
$curl_handle = curl_init("[PLAIN]http://localhost/Test/index.php");[/PLAIN]
curl_setopt($curl_handle, CURLOPT_POSTFIELDS, array("captcha"=>$capture, "number"=>$_REQUEST['q'], "submit"=>""));
[B]$html = str_get_html($output);[/B]
I have solved this by putting everything in a "with requests.session() as s:"
Thanks anyway. :D
Thread 'Is this public key encryption?'
I've tried to intuit public key encryption but never quite managed. But this seems to wrap it up in a bow. This seems to be a very elegant way of transmitting a message publicly that only the sender and receiver can decipher. Is this how PKE works? No, it cant be. In the above case, the requester knows the target's "secret" key - because they have his ID, and therefore knows his birthdate.
Thread 'Project Documentation'
Trying to package up a small bank account manager project that I have been tempering on for a while. One that is certainly worth something to me. Although I have created methods to whip up quick documents with all fields and properties. I would like something better to reference in order to express the mechanical functions. It is unclear to me about any standardized format for code documentation that exists. I have tried object orientated diagrams with shapes to try and express the...
