Understanding the Mathematical Definition of the State Ket Expansion in Sakurai
  • Thread starter Thread starter rachmaninoff
    Continuous Spectra
rachmaninoff
In Sakurai:
The state ket for an arbitrary physical state can be expanded in terms of the |x'>
|\alpha>=\int dx'^3 |\mathbf{x'}><\mathbf{x'}|\alpha>
(where the |x'> are the eigenkets of the position operator, \hat{x}|x'>=x'|x'>).
(Sakurai 1.6.4, p. 42)
My question is about how this integral is mathematically defined - since the integrand is not a complex number, the Lebesgue integral as defined in analysis1 doesn't work directly. I thought about extending the defintion to kets, defining an ordering |a> <= |b> iff every <x'|a> <= <x'|b>, is this how it works? I also noticed the equation looks very much like a Fourier series (except the basis is uncountable) - it's the same idea, an expansion in a basis set... does this work formally?
Since the explanation may be very involved, a reference to a book/section would be more than sufficient. Thanks!
(secondary question - is there a better way to TeX the above equation?)
Well, formally, everything works due to some bright ideas by Dirac. The mathematics behind this is contained (a great part of it) in the 5 volumes by Gelfand and especially in the IV-the (written with Vilenkin) and entitled: "Generalized functions: Applications of Harmonic Analysis".
Daniel.
rachmaninoff said:
In Sakurai:
|\alpha&gt;=\int dx&#039;^3 |\mathbf{x&#039;}&gt;&lt;\mathbf{x&#039;}|\alpha&gt;
(where the |x'> are the eigenkets of the position operator, \hat{x}|x&#039;&gt;=x&#039;|x&#039;&gt;).
Consider the action of both sides of the equation on an arbitrary bra <\beta|:
&lt;\beta|\alpha&gt; = \int {dx&#039;}^3 &lt;\beta|x&#039;&gt;&lt;x&#039;|\alpha&gt;
Now everything in sight is a number and so Lebesque integration works.
If you want a more overarching reason, you can appeal to the spectral resolution theorem, Stiljes integrals and functional calculus. (This approach can even manage to avoid delta "funcions", if you find that appealing)
Here's a quick sketch of how it works in the one-dimensional case.
The position operator X has the spectral resolution:
<br /> X := \int_{-\infty}^{+\infty} x |x\rangle\langle x| \, dx<br />
which merely means that
<br /> \langle \psi | X | \psi \rangle = \int_{-\infty}^{+\infty} x \langle \psi| x\rangle\langle x|\psi\rangle \, dx<br />
If you want to avoid the delta functions, the "right" way to describe the spectral resolution is in terms of projection operators: if \phi is a wave function (in the position basis), then we define:
<br /> (E_x \phi)(y) := \left\{<br /> \begin{array}{ll}<br /> \phi(y) \qquad &amp; y &lt; x \\<br /> 0 &amp; y &gt; x<br />
I don't want to work out what you're supposed to do when x = y, but I'm pretty sure it's irrelevant to the discussion.
Now, the "right" way to view the spectral resolution is via:
<br /> \langle \psi | X | \psi \rangle = \int_{-\infty}^{+\infty} x \, d \langle \psi | E_x | \psi \rangle<br />
This is a Stiljes integral, and it's well-defined because the thing after the d is a nondecreasing function. This leads us to say
<br /> X = \int_{-\infty}^{+\infty} x \, dE_x<br />
The reason we can write dE_x = |x\rangle\langle x| \, dx is because the E_x forms a continuous "distribution function", so it can be differentiated to get a "density function".
Then, if we write f(z) := 1, we can express the identity operator functionally in terms of the position operator: \hat{1} = f(X). So, the functional calculus tells us:
<br /> \hat{1} = f(X) = \int_{-\infty}^{+\infty} f(x) \, dE_x<br /> = \int_{-\infty}^{+\infty} dE_x<br /> = \int_{-\infty}^{+\infty} |x\rangle\langle x| \, dx<br />
which is a "resolution of unity".
Then, you just apply this resolution of unity to |\alpha\rangle, and you get
<br /> |\alpha \rangle = \hat{1} |\alpha \rangle<br /> = \int_{-\infty}^{+\infty} |x\rangle\langle x|\alpha\rangle \, dx<br />
None of this was needed to actually answer your question (since the integral of a linear operator is defined pointwise), but I thought you might find it appealing.
Incidentally, Real Analysis by Royden has a section on the Stiljes integral. The spectral resolution, etc, I took from the Hilbert space section at Modern Physics for Mathematicians.
You can get to that latter link, incidentally, by following the "links" button off of this forum!
In my opinion you can always appeal to the simpler formalism, which resembles the one used in statistical theory. Product of functions, integral of product of functions, no bra and ket, just functions (complex ones) and its conjugates.
Matrix formalism never showed itself as an absolutelly necessary tool.
Best wishes
DaTario
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
