Are You Struggling with Quadratic Equations?
In summary, the conversation discusses solving an equation with roots and coefficients, and the steps involved in finding the solution. The participants also mention that option B is the correct answer.
DaalChawal
87
Mathematics news on Phys.org
Hi DaalChawal,
We can write
$$(x-\alpha)(x-\beta)+(x-\gamma)(x-\delta)=2x^2-(\alpha+\beta+\gamma+\delta)x+(\alpha\beta+\gamma\delta)=0\implies $$
$$x^2-\frac 12(\alpha+\beta+\gamma+\delta)x+\frac 12(\alpha\beta+\gamma\delta) = 0\tag 1$$
Since $m$ and $n$ are roots, we must have
$$(x-m)(x-n)=0\implies x^2-(m+n)x+mn=0\tag 2$$
The coefficients of equations (1) and (2) must be the same, so we have:
$$\begin{cases}m+n=\frac 12(\alpha+\beta+\gamma+\delta)\\mn=\frac 12(\alpha\beta+\gamma\delta)\end{cases}\tag 3$$
We have
$$2(x-m)(x-n)-(x-\alpha)(x-\beta)=x^2-(2(m+n)-\alpha-\beta)x+(2mn-\alpha\beta)=0$$
Let its roots be $x_1$ and $x_2$, then we must have:
$$(x-x_1)(x-x_2)=x^2-(x_1+x_2)x+x_1x_2=0$$
Again, the coefficients must match, so we have
$$\begin{cases}x_1+x_2=2(m+n)-\alpha-\beta \\ x_1x_2=2mn-\alpha\beta\end{cases}\tag 4$$
Substitute (3) in (4) to find:
$$\begin{cases}x_1+x_2=2\cdot\frac 12(\alpha+\beta+\gamma+\delta)-\alpha-\beta = \gamma+\delta \\
x_1x_2=2\cdot \frac 12(\alpha\beta+\gamma\delta)-\alpha\beta = \gamma\delta\end{cases}\tag 5$$
Therefore (B) is the correct answer.
Thank you Sir🙂
1. What are quadratic equations?
Quadratic equations are polynomial equations of the second degree, meaning they have one variable raised to the power of two. They are typically written in the form ax^2 + bx + c = 0, where a, b, and c are constants and x is the variable.
2. Why do students struggle with quadratic equations?
Quadratic equations can be difficult for students because they involve multiple steps and require a good understanding of algebraic concepts such as factoring, completing the square, and using the quadratic formula. They also require a lot of practice to master.
3. How can I solve a quadratic equation?
There are several methods for solving quadratic equations, including factoring, completing the square, and using the quadratic formula. The method you use will depend on the specific equation you are trying to solve.
4. What are some tips for solving quadratic equations?
Some tips for solving quadratic equations include: identifying the type of equation (standard form, vertex form, etc.), checking for common factors, using the quadratic formula if necessary, and always double-checking your work.
5. How can I improve my skills in solving quadratic equations?
The best way to improve your skills in solving quadratic equations is to practice regularly. You can also seek help from a tutor, watch online tutorials, or work through practice problems in a textbook or workbook. Additionally, make sure you have a solid understanding of algebraic concepts and formulas related to quadratic equations.
  • General Math
  • General Math
  • General Math
  • General Math
