Quadratics, i was good until here.
  • Thread starter Thread starter offtheleft
The discussion revolves around finding a quadratic equation that fits three given points: A (0, 1), C (2, 6), and D (3, 10). The user initially struggles with setting up the equations, particularly with the first point, but eventually identifies that c = 1 from the equation a(0)^2 + b(0) + c = 1. After substituting c into the other equations, they derive a system of equations to solve for a and b. The conversation highlights the importance of correctly solving the system to obtain the quadratic model and notes that fitting a quadratic function to four points is not possible, suggesting the use of a cubic function instead. The user ultimately aims to clarify their understanding of the quadratic fitting process.
offtheleft
im going to try to make this as short and easy to follow as possible haha
and I am just warning, this is probably so simple that i can't even grasp it because I am reading too deeply into it.
okay, I am working with these three points:
A (0, 1)<br /> C (2, 6)<br /> D (3, 10)
i worked them into three equations, the first one is killing me though!
a(0)^2 + b (0) + c = 1 this is the one I am having trouble with, i can't set it up properly because all i have is c = 1
i have for the other two:
C. . ., 4a + 2b +c = 6
D. . ., 9a + 3b + c = 10
now, in order to get my model for y = ax^2 + bx + c
how would i set this up, other than that I am doing alright..
D. . ., 9a + 3b + c = 10now, in order to get my model for y = ax^2 + bx + c
Well from the first equation you have found that c=1, so just sub that into the following two equations and then you have a system of two equations in two variables (a and b). Why should the first one cause any trouble?
a(0)^2 + b (0) + c = 1&lt;br /&gt; this is the one I am having trouble with, i can&amp;#039;t set it up properly because all i have is &lt;br /&gt; c=1&lt;br /&gt; You SHOULD get a + 0 + c = 1&lt;br /&gt; &lt;br /&gt; Continue from there and you should have no trouble.
like i said, so simple that i can't eve grasp it.
thanks, ill see how it works out! :)
i got:
y = \frac{1}{2}x^2 + 3x + 1
c=1
No, you shouldn't. 02= 0, not 1. c= 1 is correct.
i used c = 1. I am quite confident that the answer i got(<br /> y = \frac{1}{2}x^2 + 3x + 1) is incorrect. when i plug in all the numbers, get the changes from the original y value and square it, i get all sorts of weird answers for this one. usually, its all 0's except for one value but that's not happening.
Perhaps you solved the system of equations incorrectly. Have a look at your working, and if you still can't figure it out, post your working here :smile:
okay, here's what we did in class:
four points;
A (0, 1)
B (1, 2)
C (2, 6)
D (3, 10
we went over (what I am sure everyone here, including my self, already know. its good to think about and keep fresh in my mind) how two points define a line and for a function such as a half of a parabola, (at least) three points are required.
for our first model, we chose points ABC.
i have three equations:
c =1
1a + 1b + c = 2
4a + 2b + c = 6
with that info, i don't know how i got from there to here(our first model):
\hat{y}_{1} = \frac{3}{2}x^2 - \frac{1}{2}x + 1
plug in all the numbers to get the residual (the problem i had last time, but now i can do it in my sleep).
heres what I am about to do, hopefully i can elaborate enough.
im going to plug in the numbers from all four points, not just the three that i am using for this model.
point A
\hat{y}_{1} = \frac{3}{2}(0)^2 - \frac{1}{2}(0) + 1 = 1
(y - \hat{y}_{1})^2 = 0 (the residual)
(0 - 0)^2 = 0
point B
\hat{y}_{1} = \frac{3}{2}(1)^2 - \frac{1}{2}(1) + 1 = 2
(2 - 2)^2 = 0
im posting this now and will continue immediately. this is just to be sure nothing happens and i have to redo the whole thing.
point C
\hat{y}_{1} = \frac{3}{2}(2)^2 - \frac{1}{2}(2) + 1 = 6
(0 - 0)^2 = 0
heres where it finally changes!
\hat{y}_{1} = \frac{3}{2}(3)^2 - \frac{1}{2}(3) + 1 = 13
(y - \hat{y}_{1})^2 = 9
(10 - 13)^2 = 0
so for model ABC
\sum(y - \hat{y}_{1})^2 = 9
the sum of our residual is nine
the second model is with points ABD
heres how it looks: \hat{y}_{2} = x^2 + 1
(this was done is class as well)
plug in the numbers
everything is 0 except for point C which will look like this:
heres how it looks: \hat{y}_{2} = 2^2 + 1 = 5
(6 - 5)^2 = 1
so,
\sum(y_{1} - \hat{y}_{2})^2 = 1
our third model, well, fourth, the third one is the one i am trying to figure out:
ill keep it short, i demonstrated how everything was done in the first long post. :)
this is done with points BCD
the model looks like this: \hat{y}_{4} = 4x^2 - 2
all but the first point were 0's. ill plug in the number
\hat{y}_{4} = 4(o)^2 - 2 = -2
(1 - 2)^2 = 1
so for: \hat{y}_{4} = 4x^2 - 2; \sum(y - \hat{y}_{4})^2 = 1
In your original post you said the points were A(0,1), B(2, 6), C(3, 10)
Writing y= ax2+ bx+ c, those give a02[/sub]+ b0+ c= 1 or c= 1, 4a+ 2b+ c= 6, and 9a+ 3b+ c= 10. Since c= 1, the last two are 4a+ 2b+ 1= c or 4a+ 2b= 5 and 9a+ 3b+ 1= 10 or 9a+ 3b= 9. If you multiply the first of those equations by 3 you get 12a+ 6b= 15 and if you multiply the second by 2 you get 18a+ 6b= 18. Subtracting the first from the second, 6a= 3 so a= 1/2. Then 4a+ 2b= 5 becomes 2+ 2b= 5 so 2b= 3 and b= 3/2, not b= 3.
The equation if y= (1/2)x2+ (3/2)x+ 1.
But later you give A(0, 1), B(1, 2), C(2, 6), D(3, 10). The equation y= (1/2)x2+ (3/2)x+ 1 gives y(0)= (1/2)(0)+ (3/2)(0)+ 1= 1, y(1)= (1/2)(1)+ (3/2)(1)+ 1= 3, y(2)= (1/2)4+ (3/2)2+ 1= 6, and y(3)= (1/2)9+ (3/2)3+ 1= 10. That is correct for all except B(1,2) which was NOT in the original problem. You can, in general, fit a parabola through 3 given points but not 4. There is no quadratic function whose graph will pass through all 4 points.
If you have 4 points, you should try a cubic formula: y= ax3+ bx2+ cx+ d so that the 4 points will give 4 equations for the 4 coefficients.
