Qualitative collisions questions
  • Level: Undergrad
  • Thread starter Thread starter goobertron
    Collisions
goobertron
Hello all. I have what seems to be a fairly simple problem but I need a bit of help on the reasoning and what happens in a qualitative sense if some factors change.
The problem is of e.g. a larger spherical type thing happily traveling along at a fixed velocity but with a smaller (e.g. 10x smaller by diameter) sphere adhered to the surface. This large/small pair now hits a surface.
What is the likelihood of detachment based on? I am thinking it is a function of the mass of the smaller particle and the deceleration of the combo pair as it hits the wall (i.e. if the F=ma in this scenario exceeds the adhesion force then the smaller thing detaches?)
Now, keep the smaller sphere the same size but increase the larger sphere (lets assume the same force of adhesion between the pair to keep it simple). If traveling at the same velocity as before it seems like there should be a greater chance of detachment, but is this because of momentum exchange? As you can see my Physics here is shocking!
If someone could sort out this basic issue first I'd then like to expand slightly.
Thanks!
If I understand correctly, the smaller ball is attached to the back of the larger ball and the larger ball hits the wall. In this case, yes the smaller ball will feel a greater force upon impact the more massive the larger ball because of momentum transfer. You can do this experiment very easily. Hold a large exercise ball a few inches off the ground with a tennis ball resting on top and let go. When they both fall due to gravity and hit the ground, the tennis ball with go rocketing up into the air at a surprisingly high speed. This is a fun demonstration because the balls don't pick up much speed before they hit the ground, yet the tennis ball gains a great speed on impact. It demonstrates that total velocity is not conversed, only total momentum. When a high-mass, low-velocity object transfers its momentum to a low-mass object you get high velocity!
Thanks Chris - what about if it was stuck to the side? Does a larger or smaller parent ball give a more likely qualitative detachment force?
