Quantum current density in general relativity
FunkyDwarf
Hi All,
As shown here
http://en.wikipedia.org/wiki/Klein–Gordon_equation#Gravitational_interaction
one can modify the derivative operator in the Minkowski Klein-Gordon equation to generate the GR case for an arbitrary metric.
My question is, what would the quantum current density j be in this case? Given here
http://en.wikipedia.org/wiki/Four-current
is the classical current density in the EM case but that's not really what I'm after.
Furthermore, if i generate a radial wave equation from the GR KG equation in some metric and transform it in a Schrodinger like form, can I just use the standard tools of non-rel QM and use \psi^* \frac{d}{dx} \psi for j?
Cheers!
I think a lagrangian like
<br /> \mathcal{L}=\bar{\psi}\gamma^\mu \partial^\nu \psi g_{\mu\nu}<br />
would get you essentially
<br /> \bar{\psi}\gamma^\mu \partial^\nu \psi=\theta^{\mu\nu}<br />
when varied by the metric, where the current corresponds to the 0\nu part.
But I kinda made that up, so we should keep that tentative lol.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
In Philippe G. Ciarlet's book 'An introduction to differential geometry', He gives the integrability conditions of the differential equations like this: $$ \partial_{i} F_{lj}=L^p_{ij} F_{lp},\,\,\,F_{ij}(x_0)=F^0_{ij}. $$ The integrability conditions for the existence of a global solution ##F_{lj}## is: $$ R^i_{jkl}\equiv\partial_k L^i_{jl}-\partial_l L^i_{jk}+L^h_{jl} L^i_{hk}-L^h_{jk} L^i_{hl}=0 $$ Then from the equation: $$\nabla_b e_a= \Gamma^c_{ab} e_c$$ Using cartesian basis ## e_I...
