Quantum Fields in Curved Space-times
MManuel Abad
Hello, people:
I've been wondering about the definition of Quantum Fields in Curved Space-times (CS). I know that, in flat space-time (Minkowski), the fields are defined as irreducible representations of the universal covering group SU(2)xSU(2) of SO(4) (which is basically the Lorentz group SO(1,3) under a Wick rotation of time).
Nevertheless, in general (that is in CS) your field theory is not invariant under Lorentz transformations. How then are fields defined in CS? Could you explain your answer and give some references, please?
Thanks
The simplest way is to use orthonormal frames. In this language, the tangent bundle can be thought of as a principal SO(1,3) bundle (or SO(4) after Wick rotation) over spacetime. Then fields take values in this SO(1,3) bundle or in some derived bundle (i.e., other representations of SO(1,3)).
There is some subtlety with spinors, as not all curved manifolds admit spinors (those that do have what is called a "spin structure").
Oh! These orthonormal frames are simply the tetrads, aren't they?
So no, instead of asking the fields to be representations of SU(2)xSU(2), we ask their contractions with the Vierbein to be irreps of this group. Is this correct?
Thankyou!
Yes, although for half-integer spin you should think "Clifford action" instead of "contraction".
Toponium is a hadron which is the bound state of a valance top quark and a valance antitop quark. Oversimplified presentations often state that top quarks don't form hadrons, because they decay to bottom quarks extremely rapidly after they are created, leaving no time to form a hadron. And, the vast majority of the time, this is true. But, the lifetime of a top quark is only an average lifetime. Sometimes it decays faster and sometimes it decays slower. In the highly improbable case that...
I'm following this paper by Kitaev on SL(2,R) representations and I'm having a problem in the normalization of the continuous eigenfunctions (eqs. (67)-(70)), which satisfy \langle f_s | f_{s'} \rangle = \int_{0}^{1} \frac{2}{(1-u)^2} f_s(u)^* f_{s'}(u) \, du. \tag{67} The singular contribution of the integral arises at the endpoint u=1 of the integral, and in the limit u \to 1, the function f_s(u) takes on the form f_s(u) \approx a_s (1-u)^{1/2 + i s} + a_s^* (1-u)^{1/2 - i s}. \tag{70}...
