What Are the Properties and Probabilities of Electron Spin?
In summary, the spin of an electron is described by a vector and a spin operator with components. To calculate the probabilities of finding a certain spin value, the normalization condition must be met. The expectation value of the spin operator can also be calculated. The commutation relations between the spin operators can determine if they are simultaneous observables. To normalize a state, the state-ket must be multiplied by the reciprocal of the square root of the wave function.
Hart
169
The spin of an electron is described by a vector: [tex]\psi = \left(\frac{\uparrow}{\downarrow}\right)[/tex] and the spin operator:
[tex]\hat{S} = \hat{S_{x}}i + \hat{S_{y}}j + \hat{S_{z}}k[/tex]
with components:
[tex]\hat{S_{x}} = \frac{\hbar}{2} \left[ \begin{array}{cc} 0 & 1 \\ 1 & 0 \end{array} \right][/tex]
[tex]\hat{S_{y}} = \frac{\hbar}{2} \left[ \begin{array}{cc} 0 & -i \\ i & 0 \end{array} \right][/tex]
[tex]\hat{S_{z}} = \frac{\hbar}{2} \left[ \begin{array}{cc} 1 & 0 \\ 0 & -1 \end{array} \right][/tex]
I.
i. State the normalisation condition for: [tex]\psi[/tex].
ii. Give the general expressions for the probabilities to find: [tex]\hat{S_{z}} = \pm \frac{\hbar}{2}[/tex] in a measurement of: [tex]\hat{S_{z}}[/tex]
iii. Give the general expression for the expectation value of: [tex]\left<\hat{S_{z}}\right>[/tex]
II.
Calculate the commutators:
[tex]\left[\hat{S_{y}},\hat{S_{z}}\right][/tex] and [tex]\left[\hat{S_{z}},\hat{S^{2}}}\right][/tex]
.. Are [itex]\hat{S_{y}} [/itex] and [itex]\hat{S_{z}} [/itex] simultaneous observables? Are [itex]\hat{S_{z}}[/itex] and [itex]\hat{S^{2}}[/itex] simultaneous observables?
III.
i. Normalise the state: [tex]\frac{1}{1}[/tex]
ii. Calculate the expectation values: [tex]\hat{S_{x}}[/tex], [tex]\hat{S_{y}}[/tex], and [tex]\hat{S_{z}}[/tex] for this normalised state.
Within the question details and solution attempts.
I:
i. Normalisation condition: [tex]\langle\psi|\psi\rangle[/tex] .. yes?
ii. I have calculated that:
[tex]\left[\hat{S_{x}}, \hat{S_{y}}\right] = i\hbar S_{z}[/tex]
and then know that eigenvalues of [itex]\hat{S_{z}}[/itex] are simply [itex]\frac{\hbar}{2}[/itex] times the eigenvalues of [itex]\sigma_{z}[/itex] (which is just the matrix part of [itex]\hat{S_{z}}[/itex] if that makes sense). Not sure what more to do now here though.
iii. I don't know how to go about doing this part at the moment.
II.
I have calculated the commutators as:
[tex]\left[\hat{S_{y}},\hat{S_{z}}\right] = \frac{\hbar^{2}}{2} \left[ \begin{array}{cc} 0 & i \\ i & 0 \end{array} \right][/tex]
and
[tex]\left[\hat{S_{z}},\hat{S^{2}}}\right] = 3 \hbar^{3} \left[ \begin{array}{cc} i & -1 \\ 1 & -i \end{array} \right][/tex]
.. but I don't know in either case if they are simultaneous observables? Or indeed, how I would be able to determine if so for each case?
III.
I don't understand what I need to do, as far as normalising the state as required. Once I know how to do this, can then obviously have a go at calculating the expectation values.
Hart said:
I:
For part i, that function should be equal to 1: [itex]\langle\psi|\psi\rangle=1[/itex].
For part, iii, note that
[tex]\langle S_z\rangle=\langle\psi|S_z|\psi\rangle[/tex].
That should help you a bit
Hart said:
II.
and
Not quite, but on the right track. You should be getting a number as a result, something like what you have as an answer for I. ii.
Hart said:
III.
This part requires you to actually calculate
[tex]\langle\psi|\psi\rangle=1\longrightarrow|\psi\rangle_N=\frac{1}{\sqrt{\langle\psi|\psi\rangle}}|\psi\rangle[/tex]
where [itex]|\psi\rangle_N[/itex] is the normalized state-ket.
Part I:
i. : Of course, it should be 'Normalisation Condition: [itex]\langle\psi|\psi\rangle=1[/itex]'
ii. & iii. : I still don't get how to do these parts of the question.
Part II:
I don't understand how to get the result of just a number. Can I do something like this (?) ..
[tex]\left[\hat{S_{y}},\hat{S_{z}}\right] = \frac{\hbar^{2}}{2} \left[ \begin{array}{cc} 0 & i \\ i & 0 \end{array} \right] [/tex]
[tex] ( 0 . 0 ) - ( i . i ) = - ( i^{2}) = 1
[/tex]
So:
[tex]\left[\hat{S_{y}},\hat{S_{z}}\right] = \frac{\hbar^{2}}{2} \left[ \begin{array}{cc} 0 & i \\ i & 0 \end{array} \right] = \frac{\hbar^{2}}{2}[/tex]
Part III:
Could you clarify / explain a bit more that notation that you've used?
Hart said:
Part I:
An example how to get the probability (part ii) should be given in most textbooks and should be something like this:
[tex]Probability=\frac{value\,you\,are\,looking\,for}{sum\,of\,the\,total\,possible\,values}[/tex]
The expectation value will be
[tex]\langle\hat{S}_z\rangle=\psi^*\hat{S}_z\psi=\left(1,\,1\right)\cdot\frac{\hbar}{2}\left(\begin{array}{cc}1&0\\0&-1\end{array}\right)\cdot\left(\begin{array}{c}1\\1\end{array}\right)[/tex]
Hart said:
Part II:
[/tex]
So:
Whoops, I sort of misread and then mis-spoke here. What you should find here is the same sort of thing as what you have as an answer in Part I ii:
[tex][\hat{S}_x,\,\hat{S}_y]=i\hbar\hat{S}_z[/tex]
You will likely want to double check on your second commutator. In both cases, if the commutation relation gives zero, they are simultaneous observables; if you get a non-zero answer they are not simultaneous observables.
Hart said:
Part III:
The notation is
[tex]|\psi\rangle=\left(\begin{array}{c}1 \\ 1\end{array}\right)[/tex]
so then you have the normalized wave function is
[tex]\psi_N=\frac{1}{\sqrt{\psi^*\psi}}\psi \equiv |\psi\rangle_N=\frac{1}{\sqrt{\langle\psi|\psi\rangle}}|\psi\rangle= \psi_N=\frac{1}{\sqrt{\left(1,\,1\right)\cdot\left(\begin{array}{c}1\\1\end{array}\right)}}\left(\begin{array}{c}1\\1\end{array}\right)[/tex]
Part I:
ii. I've looked in the two quantum mechanics textbooks I have to hand (Rae & Griffiths) but I can't seem to find a bit about these spin probabilities :frown:
iii : OK, so:
[tex]\langle\hat{S}_z\rangle=\psi^*\hat{S}_z\psi=\left( 1,\,1\right)\cdot\frac{\hbar}{2}\left(\begin{array}{cc}1&0\\0&-1\end{array}\right)\cdot\left(\begin{array}{c}1\\1 \end{array}\right) = \left( \begin{array}{c}\left(\frac{\hbar}{2}\right)\\ \left( \frac{\hbar}{2}\right) \end{array} \right) \left( 1 , 1\right)[/tex]
.. correct? Then I assume can combine those just like this:
[tex]\langle\hat{S}_z\rangle=\psi^*\hat{S}_z\psi= \left( \begin{array}{c}\left(\frac{\hbar}{2}\right)\\ \left( \frac{\hbar}{2}\right) \end{array} \right) \left( 1 , 1\right) = \left[ \begin{array}{cc} \left(\frac{\hbar}{2}\right)& \left(\frac{\hbar}{2}\right)\\ \left(\frac{\hbar}{2}\right)& \left(\frac{\hbar}{2}\right) \end{array} \right] = \left(\frac{\hbar}{2}\right)\left[ \begin{array}{cc} 1 & 1 \\ 1& 1 \end{array} \right] = 0[/tex]
.. yes?
Part II:
I have checked through all my calculations and recalculated the commutators as:
Firstly:
[tex]\left[\hat{S_{y}},\hat{S_{z}}\right] = \frac{i\hbar^{2}}{2} \left[ \begin{array}{cc} 0 & 1 \\ 1 & 0 \end{array}\right] = \frac{i\hbar^{2}}{2} \left( \hat{S_{x}}\right) [/tex]
So [itex]\hat{S_{y}}[/itex] and [itex]\hat{S_{z}}[/itex] are not simultaneous observables as the result [itex]\neq 0[/itex].. correct?!
Secondly:
[tex]\hat{S_{z}^{2}} = \left[ \begin{array}{cc} \left(\frac{9\hbar^{2}}{16}\right) & 0 \\ 0 & \left(\frac{9\hbar^{2}}{16}\right) \end{array} \right][/tex]
(just included for completion)
.. which seemed to have horrible factors, but they canceled with those in the other commutator [itex]\hat{S_{z}}[/itex] so that was good, giving the result..
[tex]\left[\hat{S_{z}},\hat{S^{2}}}\right] = \left[ \begin{array}{cc} 0 & 0 \\ 0 & 0 \end{array} \right][/tex]
.. then since [itex](0-0)-(0-0) = 0 [/itex] ..
Hence [itex]\hat{S_{z}}[/itex] and [itex]\hat{S^{2}}[/itex] are simultaneous observables as the result [itex]= 0[/itex].. correct?!
Part III:
Sorry, I still don't get what's going on in this question :confused:
Hart said:
Part I:
See Griffiths Section 4.4, page 154. Everything below appears there. I don't know of a QM book that doesn't cover the spin-half system.
Hart said:
iii : OK, so:
.. yes?
You may have multiplied your matrices incorrectly:
[tex]\langle\hat{S}_z\rangle=\psi^*\hat{S}_z\psi=\left( 1,\,1\right)\cdot\frac{\hbar}{2}\left(\begin{array}{cc}1&0\\0&-1\end{array}\right)\cdot\left(\begin{array}{c}1\\1 \end{array}\right) = \left( 1 , 1\right)\cdot\left( \begin{array}{c}\frac{\hbar}{2}\\ - \frac{\hbar}{2}\end{array} \right)=\frac{\hbar}{2}-\frac{\hbar}{2}=0[/tex]
I am also unsure how you turned the 4x4 matrix of all 1's into zero.
Hart said:
Part II:
Firstly:
Not quite, recall that
[tex]\hat{S}_x=\frac{\hbar}{2}\sigma=\frac{\hbar}{2}\left(\begin{array}{cc}0&1\\1&0\end{array}\right)[/tex]
So you actually have the expected result:
[tex][\hat{S}_y,\,\hat{S}_z]=i\hbar\hat{S}_x[/tex]
However, you do still end up with a non-zero value, so you are correct in saying that [tex]\hat{S}_y[/tex] and [tex]\hat{S}_z[/tex] are not simultaneous observables.
Hart said:
Secondly:
Correct. You can also show that, in general
[tex][\hat{S}_i,\,\hat{S}^2]=0[/tex]
for i=x,y,z.
Hart said:
Part III:
You need to find [itex]\psi_N[/itex], the normalized wave function, by using the expression I gave in my previous post. After you do that, you need to calculate the expectation value of the 3 components of spin, using the equation I gave you for Part I, iii (keeping in mind to correctly multiply your matrices).
I. ii.
From Griffiths' QM:
" If measure [itex]S_{z}[/itex] on a particle in the general state [itex]\chi = \left(\frac{a}{b}\right)[/itex] then can get [itex]+ \frac{\hbar}{2}[/itex] with probability [itex]|a|^{2}[/itex] or [itex]-\frac{\hbar}{2}[/itex] with probability [itex]|b|^{2}[/itex]. Since these are the only possibilities: [itex]|a|^{2} + |b|^{2} = 1[/itex] "
.. I understand that, but not quite sure how need to adapt it further.
I. iii.
so..
[tex]\langle\hat{S}_z\rangle=\left<\psi^*\hat{S}_z\psi\right>=\left( 1 , 1\right)\cdot\left( \begin{array}{c}\frac{\hbar}{2}\\ - \frac{\hbar}{2}\end{array} \right)=\frac{\hbar}{2}-\frac{\hbar}{2}=0[/tex]
III:
I'm still not doing very well with this part of the question, really don't think I get it, but this is what I have so far:
[tex]\psi_N=\frac{1}{\sqrt{\left(1,\,1\right)\cdot\left (\begin{array}{c}1\\1\end{array}\right)}}\left(\begin{array}{c}1\\1\end{array}\right)[/tex]
so..
[tex]\psi_N=\frac{1}{\sqrt{\left(1,\,1\right)\cdot\left (\begin{array}{c}1\\1\end{array}\right)}}\left(\begin{array}{c}1\\1\end{array}\right) = 1[/tex] ??!?
.. which is hopefully somewhere along the right lines, though I don't think I should be getting that result, but I can't figure out how to do the calculations to get any other result.
Hart said:
I. ii.
From Griffiths' QM:
Do you understand eigenvalue problems?
[tex]\hat{S}_z\chi=\lambda\chi\rightarrow\det\left[\hat{S}_z-\lambda\mathbb{I}\right]=0,[/tex]
then solving for [itex]\lambda[/itex]??
Hart said:
I. iii.
so..
Correct.
Hart said:
III:
so..
From what you wrote, you haven't done anything different than what I wrote in post 4. Do you remember how to multiply matrices? For a 1x2 and 2x1 matrix, you multiply them as:
[tex](a,\,b)\cdot\left(\begin{array}{c}c\\d\end{array}\right)=ac+bd[/tex]
And I'm not sure how/why you keep writing a matrix as a single number, it is not.
After getting your new wavefunction, [tex]\psi_N[/tex], you need to use the same calculation as before to find the expectation values of [tex]\hat{S}_z[/tex]:
[tex]\langle\hat{S}_z\rangle=\psi^*_N\hat{S}_z\psi_N[/tex]
And similarly for [tex]\hat{S}_y[/tex] and [tex]\hat{S}_x[/tex].
I.
[tex]\hat{S_{z}} = \frac{\hbar}{2} \left[ \begin{array}{cc} 1 & 0 \\ 0 & -1 \end{array}\right] = \left[ \begin{array}{cc} \frac{\hbar}{2} & 0 \\ 0 & -\frac{\hbar}{2} \end{array}\right][/tex]
[tex]\implies \hat{S_{z}} = \left[ \begin{array}{cc} \frac{\hbar}{2}-\lambda & 0 \\ 0 & -\frac{\hbar}{2}-\lambda \end{array}\right] \implies \lambda^{2} - \frac{\hbar^{2}}{4} = 0[/tex]
[tex] \implies \lambda = \pm \frac{\hbar}{2}[/tex] .. which are the Eigenvalues of [itex]\hat{S_{z}}[/itex]
Then the expectation value.. using formula (?)
III.
[tex]\psi_N= \frac{1}{\sqrt{2}}\left(\begin{array}{c}1\\1\end{array}\right) = \left(\begin{array}{c}\left(\frac{1}{\sqrt{2}}\right)\\\left(\frac{1}{\sqrt{2}}\right)\end{array}\right)[/tex]
[tex]\langle\hat{S}_z\rangle=\psi_{N}^*\hat{S}_z\psi_{N}=\left(\frac{1}{\sqrt{2}},\frac{1}{\sqrt{2}}\right)\cdot\frac{\hbar}{2}\left(\begin{array}{cc}1&0\\0&-1\end{array}\right)\cdot\left(\begin{array}{c}\left(\frac{1}{\sqrt{2}}\right)\\\left(\frac{1}{\sqrt{2}}\right)\end{array}\right) = \left(\frac{1}{\sqrt{2}} , \frac{1}{\sqrt{2}}\right)\cdot\left( \begin{array}{c}\left(\frac{\hbar}{2\sqrt{2}}\right)\\ \left(-\frac{\hbar}{2\sqrt{2}}\right)\end{array} \right)= \left(\frac{\hbar}{2}\right) - \left(\frac{\hbar}{2}\right) = 0[/tex]
..yes?
Then obviously need to repeat the method for [itex]\hat{S_{x}}[/itex] and [itex]\hat{S_{y}}[/itex]
Hart said:
I.
Correct!
You have already calculated the expectation value, not sure what you're asking here.
Hart said:
III.
..yes?
Mostly correct, there is a small multiplication error:
[tex]\frac{1}{\sqrt{2}}\cdot\frac{\hbar}{2\sqrt{2}}=\frac{\hbar}{4}\,\,\mathrm{not}\,\,\frac{\hbar}{2}[/tex]
Thank's for pointing out that small maths mistake, should've noticed that! :redface:
I think that it should actually be:
[tex]\langle\hat{S}_z\rangle=\psi_{N}^*\hat{S}_z\psi_{N}= \left(\frac{1}{\sqrt{2}} , \frac{1}{\sqrt{2}}\right)\cdot\left( \begin{array}{c}\left(\frac{\hbar}{2\sqrt{2}}\right)\\ \left(\frac{\hbar}{2\sqrt{2}}\right)\end{array} \right)= \left(\frac{\hbar}{4}\right) - \left(\frac{\hbar}{4}\right) = 0[/tex]
i.e. I put in minus sign by mistake towards the end, but still end up with: result = 0.
I've calculated the remaining two expectation values as:
[tex]\langle\hat{S}_x\rangle=\psi_{N}^*\hat{S}_x\psi_{N }=\left(\frac{1}{\sqrt{2}},\frac{1}{\sqrt{2}}\right)\cdot\frac{\hbar}{2}\left(\begin{array}{cc}0&1\\ 1&0\end{array}\right)\cdot\left(\begin{array}{c}\left(\frac{1}{\sqrt{2}}\right)\\\left(\frac{1}{\sqrt{ 2}}\right)\end{array}\right) = \left(\frac{1}{\sqrt{2}} , \frac{1}{\sqrt{2}}\right)\cdot\left( \begin{array}{c}\left(\frac{\hbar}{2\sqrt{2}}\right)\\ \left(\frac{\hbar}{2\sqrt{2}}\right)\end{array} \right)= \left(\frac{\hbar}{4}\right) - \left(\frac{\hbar}{4}\right) = 0[/tex]
[tex]\langle\hat{S}_y\rangle=\psi_{N}^*\hat{S}_y\psi_{N }=\left(\frac{1}{\sqrt{2}},\frac{1}{\sqrt{2}}\right)\cdot\frac{\hbar}{2}\left(\begin{array}{cc}0&i\\ -i&0\end{array}\right)\cdot\left(\begin{array}{c}\left(\frac{1}{\sqrt{2}}\right)\\\left(\frac{1}{\sqrt{2}}\right)\end{array}\right) = \left(\frac{1}{\sqrt{2}} , \frac{1}{\sqrt{2}}\right)\cdot\left( \begin{array}{c}\left(\frac{i\hbar}{2\sqrt{2}}\right)\\ \left(\frac{-i\hbar}{2\sqrt{2}}\right)\end{array} \right)= \left(\frac{i\hbar}{4}\right) - \left(\frac{-i\hbar}{4}\right) = \frac{i\hbar}{2}[/tex]
.. these correct?
Then going back to part i, my last post wasn't very clear. I was confused because I thought I'd just answered the part which was:
ii. Give the general expressions for the probabilities to find: [itex]\hat{S_{z}} = \pm \frac{\hbar}{2}[/itex] in a measurement of: [itex]\hat{S_{z}}[/itex]
.. then didn't think I'd done the next part too, which was:
iii. Give the general expression for the expectation value of: [itex]\left<\hat{S_{z}}\right>[/itex]
?! :confused:
Just looked back through the posts, ignore my last comment about part I, I see that I have actually completed all parts.
Unsure though if the calculations for part III above (i.e. expectation values) are correct?
1. What is spin in quantum mechanics?
Spin is a fundamental property of particles in quantum mechanics, which describes the intrinsic angular momentum of a particle. It is a quantum mechanical property that cannot be directly observed, but its effects can be measured through experiments.
2. How is spin represented in quantum mechanics?
Spin is represented by a quantum number, denoted by the symbol s. It can have integer or half-integer values, such as 0, 1/2, 1, 3/2, etc. The magnitude of spin is quantized, which means it can only take specific discrete values.
3. What is the significance of spin in quantum mechanics?
Spin plays a crucial role in explaining the properties and behavior of particles, such as their magnetic moment and interactions with electromagnetic fields. It also determines the allowed energy levels of particles in an atom, leading to the stability of matter.
4. How is spin different from classical angular momentum?
Spin is a purely quantum mechanical property, while classical angular momentum is a macroscopic concept. Unlike classical angular momentum, spin cannot be visualized as a rotating object, and its orientation is not affected by external forces. Also, spin has a discrete spectrum of values, while classical angular momentum is continuous.
5. Can the spin of a particle change?
No, the spin of a particle is an intrinsic property that cannot be changed. It is always conserved in quantum mechanical processes, such as particle interactions. However, spin can be measured along different axes, and its projection can change, leading to different observable outcomes.
