Quantum numbers of N/Deltas resonances
The discussion revolves around the quantum numbers of N and Delta resonances, specifically focusing on their classification and the implications of their intrinsic spins, isospin, and decay channels. Participants explore the definitions and differences between these particles, as well as the significance of quantum numbers in their characterization.
  • One participant questions the identification of quantum numbers for N and Delta resonances, noting that while J is given as 3/2 and L is inferred from P, S appears to be 1/2, leaving n as the distinguishing factor.
  • Another participant asserts that the spins of N and Delta are intrinsic and that L and S do not apply, suggesting that they are distinguished by isospin.
  • It is noted that N's have isospin 1/2 while Deltas have isospin 3/2, which some participants argue is the fundamental difference between them.
  • There is a discussion about the role of isospin, with some participants claiming it is not fundamental and questioning how it relates to the differences in particles like Lambda and Sigma.
  • One participant proposes that in the quark model, isospin can be disregarded, and the difference between N and Delta lies in their quark spin states.
  • Another participant raises a question about how to write analogous states for Sigma^- (dds) states and whether mass would be the only distinguishing factor.
  • There is mention of older literature discussing pi-N scattering and the classification of states, with a request for specific references on the topic.
  • One participant expresses confusion regarding the assignment of L as a quantum number versus its role in decay channels, indicating a lack of consensus on this point.
  • There is a correction regarding the naming of a spin 3/2 dds state, with discussions about its classification and the implications of isospin on its designation.
Participants express differing views on the significance of isospin and the classification of quantum numbers, indicating that multiple competing views remain. The discussion does not reach a consensus on the fundamental differences between N and Delta resonances or the role of L in their characterization.
There are unresolved questions regarding the definitions and roles of quantum numbers, particularly L and S, and how they relate to decay channels versus intrinsic properties. The discussion reflects a complexity in the classification of particles that may depend on the theoretical framework used.
headbomb
I've been working on something and I seem to have hit a noose.
The PDG lists many N/Delta resonances, but let's focus on four of them, each with JP=3/2+:
*N(1720), P13, http://pdg.lbl.gov/2009/listings/rpp2009-list-N-1720-P13.pdf
*Delta(1232), P33, http://pdg.lbl.gov/2009/listings/rpp2009-list-Delta-1232.pdf
*Delta(1600), P33, http://pdg.lbl.gov/2009/listings/rpp2009-list-Delta-1600.pdf
*Delta(1920), P33, http://pdg.lbl.gov/2009/listings/rpp2009-list-Delta-1920.pdf
where spectroscopic state is noted L2I 2J.
Now, if I want to identify the quantum numbers of these particles, J is given as 3/2, from P we know that L is 1, and thus S needs to be 1/2 (|J|=|L+S|, ..., |L-S| in integer steps). And now I'm left with only n to distinguish between a N and a Delta, which makes no sense. What am I doing wrong?
This spins of the N and the Delta are intrinsic spins. There is no L or S.
The parity refers to how they behave in decay to a pi N state.
Then the Delta(3/2) or the N(3/2) each decay to L_pi=1 and s_N=1/2.
They are distinguished by their Ispin.
N's have isospin 1/2. Deltas have isospin 3/2. That's the definition of the difference.
If there is no L, then why is L given (the P in P13/P33, see http://pdg.lbl.gov/2009/reviews/rpp2009-rev-n-delta-resonances.pdf). If there is no S, then why is J not equal to L?
Isospin is not fundamental. I want the fundamental difference between the N(1720) and the Delta(1920)/Delta(1600) in terms of fundamental quantum numbers.
What do you mean it's not fundamental? Why then are the Lambda and Neutral Sigma different particles?
Different internal symmetries (different wavefunctions).
I just might have answered my own question.
As I said in my post, the L and S refer to the decay channel -->pi + N, or to the resonance channel in pi-N scattering.
Ispin is needed if quarks are not used. In the quark model, Ispin can be dispensed with,and the N and Delta difference is in their quark spin states. The same is true for the Lambda and Sigma.
Any book or online refs I can check on that topic?
Yes, which then leads to the question, how would one write the analogous states for the equivalent [tex]\Sigma^-[/tex] (dds) states? These would all be P33 states [edit:I meant P23, my bad]. Would mass be the only distinguisher?
Most older books on particle physics would discuss pi-N scattering.
There is a spin 1/2 Sigma-(dds) with the three quark spins adding up to 1/2.
The spin 3/2 dds state is now called the Y*. Its three quark spins add up to 3/2.
The Y* is not a P_33 state because its isospin is 1.
Yes, but do you know of a book that specifically discuss these assignments of L with particular channels (instead of being a quantum number). Also, I've spoken with my teacher about this and he says that his impression is that L indeed is a quantum number. We are both quite puzzled by this.
That doesn't make any sense. Spin three dds states are called [tex]\Sigma[/tex], just like the spin 1/2 dds states are called [tex]\Sigma[/tex]. The only variation out there is to place a star in the decuplet Sigmas ([tex]\Sigma^*[/tex]). If there's something called the Y* with the dds assignment, then it must've been a placeholder name for a resonance that will be changed into a [tex]\Sigma^[/tex] or [tex]\Sigma^*[/tex] as soon as the dds assignment is confirmed.
And I meant P23, my bad.
I'm sorry, Ihad the notation backwards. It was called the Y* years ago, but now is just listed in the pdg as Sigma, not even having the star for 3/2. Sigma- now refers to any quark model state dds of any J.
If you look at the summar tables for Sigmas, there are some with L>1 and J>3/2.
For instance, §(1775) D_15 is observed as a bump in pi-Sigma final states with angular distribution corresponding to L=2 and J=5/2.
10K
10K
  • · Replies 16 ·
