Quantum Physics in the Body: Energy
The discussion revolves around a problem involving the energy requirements for a pulsed dye laser used in medical applications, specifically for removing vascular lesions by evaporating blood. The problem includes calculations related to energy delivery, power output, and photon count based on the laser's specifications and the properties of blood.
  • Participants discuss the energy needed to vaporize blood and the temperature changes involved. There is an exploration of the relationship between energy, mass, specific heat, and phase transitions. Questions arise about the assumptions regarding the boiling point of blood and the calculations for energy delivery and power output.
Some participants have made progress in their calculations and have shared their findings, while others have raised questions about the assumptions made regarding temperature and phase transitions. There is a collaborative effort to clarify concepts and verify calculations, with some participants expressing confidence in their results.
Participants are working within the constraints of a homework assignment, which may limit the information available for discussion. The problem requires careful consideration of physical properties and assumptions about the behavior of blood under laser treatment.
TJDF
A pulsed dye laser emits light of wavelength 576 nm in pulses of 456 µs duration. This light is absorbed by the hemoglobin in the blood and can therefore be used to remove vascular lesions, such as certain blemishes and birthmarks. To get an estimate for the power required for this laser surgery, assume that blood has the same specific heat capacity (4190 J/(kg·K)) and heat of vaporisation (2.256×106 J/kg) as water. Suppose that each pulse must remove 2.5 µg of blood by evaporating it, starting at 33 °C.
a) How much energy must the pulse deliver to the blemish?
b) What must be the power output of the laser?
c) How many photons does each pulse deliver?
Q = m*c*delta(t)
f = c/wavelength
E = h*f
I don't even know how to start this... but I'd really appreciate the help, especially an answer to part a.
Okay... I'm starting to make some progress, but I keep getting stuck in my ideas...
Energy to Vaporize = Q = m*l = (2.5e-9 kg)(2.256×106 J/kg) = 5.64e-03 J...
so...
Q = m*c*delta(t) ; delta(t) = Q/(m*c) = 5.64e-03 J/[(2.5e-9 kg)x(4190 J/(kg·K))]
delta(t) = 538.42 K
but... I don't understand... This means there's a difference...
33°C = 306.15 K, so there's a difference of 232.275 K.
What can I do with this?
Your thermal energy for vaporizing blood is correct. But you start out at 33°C and blood might not undergo a phase transition then, right? You might have to add additional heat to get the temperature high enough to reach the temperature at which blood transitions from a liquid to a gas.
It looks like you attempted to find the temperature at which blood transitions from a liquid to a gas. My guess is is that you're supposed to use the boiling point of water.
Ah, that's very interesting!
I never though of using that 100°C boiling point.
so, with that...
and
Q = m*c*delta(t) = (2.5e-9 kg)(4190 J/(kg·K))(67K) = 7.01825e-4 J
adding these two values... Q1 +Q2 = 6.341825e-3 J, which makes sense...
now,
ideas there?
Well how do we define power?
Okay, I figured out b...
I thought, since a J/s is a W...
Then the energy, (6.341825e-3 J)/0.000456s = 13.9076 W...
so far, so good... now, c.
I figured out c too!
Thank you so much for your help!
Looks right so far.
EDIT: Nice, good job.
18K
