Quantum physics - probability density,
6 replies · 2K views · last reply
Jillds
consider a particle at an interval ##[-L/2, L/2]##, described by the wave function ## \psi (x,t)= \frac{1}{\sqrt{L}}e^{i(kx-wt)}##
a) Calculate the probability density ##\rho (x,t) ## and the current density ## j(x,t)## of the particle
b) How can you express ## j(x,t)## as a function of ##\rho (x,t) ## and the velocity ## v##?
c) What is de probability to find the particle at the intervals ##[-L/2, L/2]##, ##[-L/2, 0]## and ##[0, L/4]##
(note: not sure whether 'current density' is the proper translation of the term I have in Dutch for j(x,t).
##\rho (x,t) = \psi^* (x,t) \psi (x,t)##
## j(x,t) = - \frac{i \hbar}{2m} \big[ \psi^* (x,t) \frac{\partial}{\partial x}\psi (x,t) - \psi (x,t) \frac{\partial}{\partial x}\psi^* (x,t) \big]##
##P(\Omega)= \int_{\Omega} |\psi (x,t)|^2 dx##
no clue on the relevant equation for b and c
a) ##\rho (x,t) = \frac{1}{\sqrt{L}} e^{-i(kx-wt)} . \frac{1}{\sqrt{L}}e^{i(kx-wt)} = \frac{1}{L} e^{-i(kx-wt)+i(kx-wt)} = \frac{1}{L} e^0 = \frac{1}{L} ##
## j(x,t) = - \frac{i \hbar}{2m} \big[ \frac{1}{\sqrt{L}} e^{-i(kx-wt)} \frac{\partial}{\partial x}\frac{1}{\sqrt{L}}e^{i(kx-wt)} - \frac{1}{\sqrt{L}} e^{i(kx-wt)} \frac{\partial}{\partial x}\frac{1}{\sqrt{L}}e^{-i(kx-wt)} \big]##
## = - \frac{i \hbar}{2m} \big[ \frac{1}{L} e^{-i(kx-wt)} e^{i(kx-wt)} ik - \frac{1}{L} e^{-i(kx-wt)} e^{i(kx-wt)} (-ik) \big]##
## = - \frac{i \hbar}{2m} \big[ \frac{ik}{L} + \frac{ik}{L} \big]##
## = - \frac{i \hbar}{m} \frac{ik}{L} = \frac{\hbar k}{m L}##
b) I was not sure how to interprete the question, express first ## j(x,t)## as a function of ##\rho (x,t) ## AND afterwards in relation to velocity, OR all at the same time?
I have suggested for myself at least that ## j(x,t) = \frac{\hbar k}{m} \rho (x,t) ##
I have no idea how the velocity comes into that.
c) For the last part I have
## \frac{1}{L} \int_{-L/2}^{L/2} dx = \frac{x}{L}|_{-L/2}^{L/2} = 2L/2L =1##
Since the second interval is half of the first interval the probability should be 1/2, and checking the integral that is what I got. Same logic applies for the third given interval, which is a 4th of the first, and the probability is 1/4.
Can someone please review what I did solve, and whether I applied the correct logic or proper techniques. And can someone help me out with the velocity part?
Jillds said:
b) I was not sure how to interprete the question, express first j(x,t) as a function of ρ(x,t) AND afterwards in relation to velocity, OR all at the same time?
There is just one equation that combines them and has a nice expression. Your wave function describes a moving wave. What is its (phase) velocity?
(a) and (c) look fine.
I know there a continuity equation: ## \frac{\partial}{\partial t} \rho(x,t) + \frac{\partial}{\partial x} j(x,t) = 0 ##. Is that the one you mean?
ETA: correction on the continuity equation per mfb's following comment
That continuity equation does not look right (edit: the edited version is correct now), but that is not what I meant.
What is the phase velocity v of your wave? It is the same as in the classical case.
phase velocity : ##v_p = \frac{\lambda}{T} = \lambda f = \frac{\omega}{k} ##
group velocity : ##v_g = \frac{\partial \omega}{\partial k} ##
I know I could rewrite the wave in its classic notation as ## \psi (x,t) = \frac{1}{\sqrt{L}} sin (kx - wt) ##
I know the phase velocity is ## v_p = \lambda f = \frac{\omega}{k}##
But I don't yet see how this relates to the probability density and j(x,t)... Help very much appreciated.
Found the solution:
De Broglie: ##p = \hbar k##
Classical mechanics: ## p=mv##
Hence, ## j(x,t) = \frac{\hbar k}{mL} = \frac{p}{mL} = \frac{v}{L} = v \rho(x,t)##
So, I started out correct by replacing the ## \frac{1}{L}## with the ## \rho##, but failed to recognize De Broglie relation and to apply Classical mechanics in that.
