Quantum theory and the implications on human life
27 replies · 6K views
iforu
Hey guys,
I’m interested in knowing if there are any known implications of quantum theory in the macroscopic scale, regarding randomness. Small particles behave probabilistically, but that has any consequence in the macroscopic or in the microscopic (but higher scale than those particles – like molecules, etc) deterministic cause-effect world?
Example: the position of the eletron is random by nature, but that radomness implies randomness in the orbital properties and chemical reactions that atom can make? Or the ''randomness effect'' just ends in that smaller particles?
The undeterministic quantum world affect our deterministic world of classical physics/chemistry?
Thank you
Of course it does - chemical properties are basically all quantum effects.
For example that electrons occur in shells and chemical reactions depended on those shells.
Even life is dependent on it. My understanding, from very dimly rememberd biology classes, is that's because carbon can form 4 bonds which is quantum mechanical in nature.
You will probably find Erwin Schrödinger's famous What Is Life of interest:
https://www.amazon.com/dp/1107604664/?tag=pfamazon01-20
Just one of its many gems:
'The mutations are actually due to quantum jumps in the gene molecule'
Thanks
Bill
Thanks
Bill
Thanks for the answer.
I know that those quantum properties have influence on the type of chemical reactions that occur (etc), but those properties are constant right? I'm asking a different question here. My question is if the undeterministic nature of those subatomic particles implies thar our world is undeterministic (random by nature). When I say ''our world'', I mean the part of nature that influences us most (directly if you wish) - macroscopical level and bigger particles.
I don't know if I'm explain my problem right or if it makes any sense.
I know that those quantum properties have influence on the type of chemical reactions that occur (etc), but those properties are constant right? I'm asking a different question here. My question is if the underteministic nature of those subatomic particles implies thar our world is underministic (random by nature). When I say ''our world'', I mean the part of nature that influences us most (directly if you wish) - macroscopical level and bigger particles.
But are you not able to determine this on your own? When you decide to get up from your chair, did that happen, or was there some uncertainty in whether you are able to determine that you got off your chair or not?
Our classical world hasn't changed, even after we know about QM, and it is also why many people found QM to be strange, because it doesn't fit into what we know of with our ordinary world. There are ongoing research into trying to find this boundary between the strange world of QM and the familiar world that we are used to.
In the meantime, if you commit a crime, you cannot invoke QM as your defense.
Zz.
Its an inherently unknowable question. Chaotic behavior in deterministic systems like Classical mechanics means they are for all practical purposes undeterministic. And powerful theorems from probability such as the law of large numbers show that often deterministic behavior emerges from a probabilistic basis.
The bottom line here is given any deterministic theory one can find some kind of underlying basis for it that is probabilistic (eg QM implies classical mechanics in the classical limit) and conversely (eg Bohmian mechanics is a deterministic explanation for QM).
Thanks
Bill
Zz.
I think It's not too easy to answer your chair problem, because if the chemical reactions involved on the decision were random, you could say the action was random. Scientists don't know how to explain everything about the brain. It was just making a hypothesis. But from what I can see, altough I'm not aware of the new developmentw in that area, the evidence seems to lead to the conclusion that the brain works in a deterministic way , with classic eletromagnetism (or is not like that?). However, a lot of action we make seem to have a cause in the past
Thanks
Bill
Chaotic behavior function like when you throw a dice? When we throw a dice, we say It's random, but really, if we knew all the variables related to the dice throwing, we could predict the number, so it is deterministc.
I read somewhere that the only true ramdomness is quantum mechanics. But I guess we never know if scientist will find tommorow that the particules do not behave randomly, there is pattern and function deterministically, caused by something. Or am I wrong?
iforu said:
Or am I wrong?
You are on the right track.
Does the world operate deterministically or randomly is a meaningless question. We have no way of knowing if it really depends on a deeper level that operates differently.
Anyway this is really getting off QM and the mods will likely, correctly, close it.
Thanks
Bill
Thanks
Bill
Ok, thank you :)
Just to finish, because this question it's not about QM: chaos theory/chaotic behavior is undeterministic in the same way scientific community accepts QM is, or is like the dice throwing I was talking about?
iforu said:
Ok, thank you :)
This is incorrect. Chaos theory and chaotic behavior are completely deterministic. The definition of chaotic behavior is that a small change in the initial parameters can result in a wildly different outcome, so that you really can't predict what will happen when you tweak those parameters. It has nothing to do with it not being deterministic.
Zz.
iforu said:
Ok, thank you :)Just to finish, because this question it's not about QM: chaos theory/chaotic behavior is undeterministic in the same way scientific community accepts QM is, or is like the dice throwing I was talking about?
No.
There are two issues here that are getting mixed up.
One issue is in a deterministic theory you can get chaotic behavior. This is when small errors grow, so in practice, even though its in principle deterministic, it can't be used to predict anything with reasonable certainty. The determinism is practically useless.
The other issue is given a deterministic theory you can find a model where that determinism emerges from a deeper probabilistic layer - classical mechanics is an example of that where it emerges from QM. And conversely is given a probabilistic theory you can hypothesize an underlying layer that is deterministic and its lack of knowledge of initial conditions, or something like that, that leads to probabilistic behavior - Bohmian Mechanics does that with QM. What this means is its inherently unknowable if nature is fundamentally deterministic or probabilistic. It would seem to be an unknowable question.
Thanks
Bill
To get determinism; most would agree on definite properties, in the fundamental building-blocks of nature, as a prerequisite.
Many important experiments have shown empirically that definite properties are not compatible with predictions of quantum theory, in which the Stern–Gerlach experiment is just one of them.
https://www.youtube.com/watch?v=uqDlIgUDEIA
This video might look contradictory, because here the classical magnets show "analog" behavior and the quantum electrons show "digital" (i.e. only up/down spin), which might be misinterpreted as definite. However, if we run this measurement in a sequence of three magnets, passing only the upper beam to the next, measuring spin along the z → x → z axis, still will result in a 50/50 up/down, after the last magnet. That's because of QM superposition of indefinite properties.
So, what about randomness? Well, maybe the most famous experiment of all, the double-slit experiment, shows in a very apparent way that the fundamental nature of our world is intrinsic random.
If we run single electrons or photons, one at a time, there is no way to know in advance which slit it will go thru (not even for Bohm), and if we try to measure which slit, the interference pattern will disappear. Now, one might think that if we just had very fine-tuned and sensitive instruments, we could "sneak a peek", and get which-slit information anyway. But this is impossible. In fact, it turns out that if the laws of nature were such that they provided us with an option to mathematically determine in advance which slit the quantum particle will go thru – the interference pattern would disappear!
Now, I leave it to you to believe in any philosophical interpretation; that states that the true nature of the world, despite of experimental facts, still is perfectly determined – we're just forbidden, by both theory & experiments, to find this "delicate fact" out ...
Personally, I prefer Occam's[/PLAIN] razor. :wink:
As bhobba pointed out; quantum effects is an intrinsic part of the genetic evolution, and besides "jumps", we are bombarded with ultraviolet light and cosmic rays every second, and some might cause mutations, while others pass right through.
If this seems to 'trivial'; why not buy a quantum hardware random number generator, and travel to Las Vegas!? :biggrin:
Say hwuht!? This is the most outrageous thing I ever heard!
(:smile:)
Quantum uncertainty does not imply that results are truly random. Quantum states are not fully determined - and when they are resolved there is convincing evidence that "collapsed" state is not locally determined. But this is far from evidence against determinism.
On the other side, when a quantum state collapses, there is no possibility of predicting with certainty what its state will be and the result can be used to generate a number sequence that is as random as any other known to science.
Do you suggest that QM uncertainty imply that results are determined?
Do you have any evidence for determinism?
It sure looks like true randomness to me...
As random? Can you specify any random source that is more accurate and trustworthy than QM?? That for example, can preserve 100% true randomness for 4.47 billion years, like uranium-238??
Do you agree that (contrary to any classical phenomena and initial conditions) we are on a theoretical level "doomed" to never predict the decay of an alpha particle in the uranium above, nor which slit an electron will go thru in the double-slit experiment?
Because if we do – we will change the outcome of physical experiments!
As bhobba correctly said in #11, it appears that no experiment can say whether "reality" is truly deterministic or random. Randomness and determinism can arise from each other, so true randomness or determinism are properties of theories. If we know a theory is the final theory, then we will know whether "reality" is truly deterministic or random. However, while an experiment can tell us that a theory is consistent with observations, it cannot tell us that a theory is final.
What we can say is that quantum mechanics is a theory in which randomness is fundamental, and that all observations so far are consistent with quantum mechanics.
atyy, do you agree that if "the final theory" turns out to be (nonlocal) deterministic, this theory is – already by knowledge available today – handicapped in such a way that it is forbidden to make any determined predictions about QM outcomes, like in the double-slit experiment?
Whereas if "the final theory" turns out to be intrinsic random, there is no such reservations, and we are free to dig as far as we wish into the wonders of nature.
Agreed?
(Personally I don't understand how a "final theory" could survive the restriction above... :eek:)
DevilsAvocado said:
atyy, do you agree that if "the final theory" turns out to be (nonlocal) deterministic, this theory is – already by knowledge available today – handicapped in such a way that it is forbidden to make any determined predictions about QM outcomes, like in the double-slit experiment?[/I]
I don't agree. Bohmian mechanics is an example of a theory that reproduces all non-relativistic quantum mechanics, and is deterministic. Bohmian mechanics predicts deviations from quantum mechanics. There is a concept of "quantum equilibrium" in Bohmian mechanics that is analogous to the concept of "thermal equilibrium" for classical mechanics. The apparent randomness of quantum mechanics happens only in the restricted "quantum equilibrium" regime of Bohmian mechanics, just as "thermal equilibrium" is a restricted regime of classical mechanics.
Whether Bohmian mechanics works for relativistic quantum theories is still being researched. However, since all present quantum field theories can be thought to have a cut-off, above which they are not relativistic, it can be argued that Bohmian mechanics can in principle also explain quantum field theory.
If I understand you right; you are saying that the option to deterministically in advance predict which slit a single electron will go thru in the double-slit experiment – is still open and very possible in Bohmian mechanics. All it takes is more clever theoretical research and maybe experiments...
Correct??
Definitely more experiments, since Bohmian mechanics is basically saying there is some regime of nature in which quantum mechanics fails. In that regime, we could maybe get no randomness in the double slit experiment. Of course, we don't expect quantum mechanics to be falsified for any current double slit experiment, so a better place to look might be the early universe. An example is Colin and Valentini's http://arxiv.org/abs/1306.1579 Phys. Rev. D 88, 103515 (2013).
Aha! Gotcha! :devil:
(the Devil said with tongue in cheek)
Check out Nobel laureate Richard Feynman @49:45, in this good oldie from Cornell University 1964, and tell me where he is wrong:
Richard Feynman on the Double Slit Paradox: Particle or Wave?
https://www.youtube.com/watch?v=hUJfjRoxCbk
http://www.youtube.com/embed/hUJfjRoxCbk
To me it's crystal clear: It's forever mathematically impossible to have predetermined hidden variables telling you in advance which slit – because the sum of the two slits doesn't add up to the observed interference pattern! A simple but brutal fact (if one likes determinism).
They way Bohmian mechanics get pass this little obstacle is by stating that the initial position is not knowable or controllable by the experimenter, but Feynman has shown that problem is 'slightly' larger than this...
But of course, good old Dick could be wrong, I just want to know why? :wink:
Here's my guess. Feynman was wrong, because the experiment with both slits open doesn't have to be the "linear sum" of the experiment with one or the other slit open. In Bohmian mechanics, the wave function of the two slit situation is the linear sum of the one slit situations (consistent with Feynman's intuition), but the wave function affects particle position nonlinearly, so that the particle position in the two slit experiment is not the linear sum of the particle positions in the one slit experiments. I hope someone else who understands Bohmian mechanics better can say something more definitive.
Feynman is, of course, wrong! Essentially, this is because in Bohmian mechanics the wave function evolves and intereferes independently of initial particle positions and independently of your knowledge of these positions. So let us suppose that we know the exact initial position of each Bohmian particle. Then we also know the final position of each particle on the screen. And yet, if we consider all initial particles (not picking only those with some preselected positions), then the collection of all final particle positions will form the standard interference pattern.
This is, indeed, illustrated by picture in
http://en.wikipedia.org/wiki/Bohmian_quantum_mechanics#Two-slit_experiment
which you have certainly already seen before.
@Demystifier, could you comment on whether my post #22 is right or wrong? (Thanks!)
I was not arguing for either determinism or the lack of determinism. I was only noting that Heisenberg uncertainty does not imply a lack of determinism.
I have no evidence either way, but I would argue for determinism on two grounds:
1) The scientific method starts with a hypothetical model that can be tested. Introducing a model that simply asserts that the results are truly random, with no cause what-so-ever, rails against the common scientific attitude and practice.
2) If the end result of a QM measurement is truly arbitrary, then it is as if the decision came from outside the universe. That means that the total amount on information within this universe was increased. This would be a violation of information conservation. Information conservation is not an accepted physical law, but it is a favored one.
When I wrote "as random", I was thinking of using QM to generate a very long binary random string - where the measurement of randomness would be the ability to find ways of reliably compressing the binary string. If WinZip can compress it, it isn't random.
I agree - but there's some confusion here. In a double slit experiment, we usually never find out which way the electron went - because it didn't take any specific path. If we ever (before or after the experiment) identify which way the electron traveled, it becomes a classical experiment.
It's actually pretty tricky to pose the question you intended to ask. What you're asking (approximately) is whether we will ever be able to predict which detector will be struck when two detectors are placed so that each one is obstructing one of the slits. My answer is, assuming the experiment is set up correctly, it should be theoretically impossible for us to collect enough information to make predictions better than random guessing. But to understand why the question is still not posed correctly, imagine that we have a fully entangled duplicate of the system. It should act exactly as our original system and provide a method for predicting the results - or would it? In any case, if a method was found to make the prediction, the act of collecting the data on which the prediction is to be based would drive the electron to the predicted slit and, if the detectors are removed, would spoil the interference pattern.
@.Scott: I'm sorry, but I'm short of time today... I have to come back later/tomorrow.
Okay, but isn't it just a little bit frustrating to never be able to nail down those little bast*rds? :smile:
And others would prefer Occam's razor in favor of gazillion forked universes or heavy deterministic 'overcoats' without any experimental verification whatsoever...
Okay... maybe I'm misinterpreting... you are not claiming that WinZip has the capacity to refute QM, right?? :rolleyes:
(Even though it would be pretty cool to have a hacker receiving the Nobel Prize in Physics! :biggrin:)
Agreed! :thumbs:
Agreed!
Nope, entanglement and interference don't party together.
Yup! This is the same conclusion Richard Feynman makes, and he is famous for always hitting the right knobs! :wink:
