Quantum Visibility: Imax & Imin Explained
  • Context: Graduate
  • Thread starter Thread starter suma
    Quantum
The discussion revolves around the concept of visibility in quantum interference, specifically in the context of the Young's double-slit experiment. Participants explore the definitions and implications of visibility, represented by the formula V = (Imax - Imin) / (Imax + Imin), and seek clarification on the terms involved.
  • One participant asks for clarification on what Imax and Imin refer to in the context of visibility in quantum interference.
  • Another participant explains the probability distributions for different cases of interference, noting that a 50/50 mixture results in no interference, while pure cases yield different visibility values.
  • A participant questions whether visibility refers to the chance of observing interference and seeks to confirm if the V in the equation is indeed the visibility.
  • One participant clarifies that L(x) and R(x) are probability amplitudes related to photon detection at the screen after passing through the slits, rather than operators.
  • A hypothetical scenario is presented where a device allows 80% of photons to pass through the slits while randomly obstructing one slit 20% of the time, resulting in a visibility of V = 0.8.
Participants express uncertainty regarding the definition and implications of visibility, with no consensus reached on its meaning or the interpretation of the variables involved.
Some assumptions about the nature of the probability amplitudes and the conditions under which visibility is calculated remain unresolved. The discussion includes varying interpretations of visibility and its relation to interference patterns.
suma
Hi,
What does visibility in interference mean? in quantum mechanics?
V = Imax-Imin/Imax+Imin
but which part of the interference does Imax and Imin refer to?
thanks
With a 50/50 mixture of left (L) and right (R) in the Young slits the probalility on the screen is
##L(x) \overline L (x) + R(x) \overline R (x)## you have no interference.
in the pure case the probability is
##[L(x) + R(x)] \overline {[L(x) + R(x)]}##
These are special cases of
##L(x) \overline L (x) + R(x) \overline R (x) + V[L(x) \overline {R(x)} + R(x) \overline {L (x)}]## for V = 0 and V = 1.
Take V = 0.7 and see what it gives with a graph plotter
thanks,
but what is the meaning of visibility? does visibility means chance of seeing interference?
is the V in your equation the visibility? there is a minus sign in the intensity form
are L(x) and R(x) operators?
thanks
No L(x) and R(x) are the probability amplitudes that the photon hits the screen at x after having passed thru the Left slit (or the Right slit)
Suppose now that behind the slits there is a device that let 80% of the photon pass thru the unmodified Young slits but that every 20% it randomly obturates one of the slits.
We will have V = 0.8
The probability curve on the screen will be sandwiched between two envelopes.
It will look like that
  • · Replies 24 ·
