nuby
- 336
- 0
If a string is attached to a weight and swung around overhead, is the force that creates tension on the string centripetal, centrifugal, or both?
nuby said:If a string is attached to a weight and swung around overhead, is the force that creates tension on the string centripetal, centrifugal, or both?
Still insist on using that archaic meaning of centrifugal force as the "reaction" force to centripetal force? If so, then it's simple: The string pulls the object (centripetal) and the object pulls the string ("centrifugal"). Can't have one without the other.nuby said:I think centripetal would always exist in the string. But, centrifugal (reactive) force would depend on the rigidity of the string.
Doc Al said:Still insist on using that archaic meaning of centrifugal force as the "reaction" force to centripetal force? If so, then it's simple: The string pulls the object (centripetal) and the object pulls the string ("centrifugal"). Can't have one without the other.
One more time though: This is an old-fashioned usage of the term centrifugal. The modern usage is as a "fictitious" force that appears when viewing things from a rotating frame of reference.
archaic? Was it true? For the example which nuby explain,Doc Al said:Still insist on using that archaic meaning of centrifugal force as the "reaction" force to centripetal force? If so, then it's simple: The string pulls the object (centripetal) and the object pulls the string ("centrifugal"). Can't have one without the other.
What are the action-reaction forces? Say the one is centripetal force, what is the other?a string is attached to a weight and swung around overhead
I thought the second one was inertia - the object's tendency to continue moving in a straight line.Doc Al said:The "action/reaction" pair is: String pulls on object & object pulls on string. When considering the motion of the string, we call the first force the centripetal force. The second force has no particular name. (Some folks call that second force the "centrifugal" force--but that's nonstandard usage. Old-fashioned and out of date!)
As Hootenanny already explained, the string pulls on the object and the object pulls on the string. Two very real forces--nothing "fictitious" here.Volcano said:Other hand, for this example, I suppose the pair of centripetal force is a force like so; say we pull a body by means of a string in space. There is no other force(friction, weight) then we apply. But anyway string will have has a tension. If this true, this is inertia force. But it is a pair-less fictitious force. Then how will we call it? :-/
I tried to understand second force on weight which asked in first post. Doc_Al said has no particular name and DaveC426913 said inertia. You and Doc_Al are right. I must be mad. Don't know how and why confused so much. Ok.Hootenanny said:What is this fictitious force your talking about?
No, centripetal force is the force pulling inward. Centrigual force is plain-old garden variety inertia as seen from the rotating reference frame. (i.e. if the string tied to the rotating bucket of water were to break, the bucket would continue in a straight line tangential to the bucket's former circular path).patrickdt10 said:centrifugal force is a misnomer. what people refer to as centrifugal force is actually centrepetal force to the best of my knowledge.
