Question about Centripetal Force
In the physics experiment, increasing the rotation speed of a mass connected to a spring caused the radius of rotation to increase due to the relationship between centripetal force and velocity. As the mass rotates faster, the outward force experienced, often referred to as centrifugal force, increases, requiring greater tension in the string to maintain circular motion. This tension is what stretches the spring, as it counters the outward pull of the mass. When the hanging weights are removed, the spring's tension becomes dominant, pulling the mass inward. Understanding these dynamics clarifies the interaction between centripetal force, velocity, and tension in the system.
theintarnets
So in a physics experiment, we used a motor to rotate a mass connected to a spring by a string and pulley until it's radius of rotation increased to a certain point. My question is, why did rotating it faster increase the radius of rotation? Centripetal force pulls objects inward, but the mass looked like it was being pulled outward the faster it rotated. I have a feeling that it has to do with the magnitude and direction of velocity as it increased, but I'm not sure. When the mass was being pulled outward, it also pulled on the string and caused the spring to stretch, but I don't understand why that happened either. Can someone explain this to me please?
The picture I have shows the setup before removing the hanging mass and pulley on the left and before rotating. When you remove the hanging weights, the spring pulls the suspended mass towards itself, I guess because the tension in the string is reduced and can no longer counter the tension in the spring.
The centrifugal force should not be considered as some usual force like electrostatic force or gravity, rather, it refers to the composition of some forces.
When it rotates faster, the velocity increases. In this case, we need to increase the centrifugal force to stop it from flying away. Actually,the radial velocity tends to pull the string outwards until the tension is strong enough to keep it in a circular orbit.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
