Question about isolated points.
  • Thread starter Thread starter cragar
    Points
cragar
If I just had the set containing \pi on the real line.
So this is an isolated point. Is this set closed?
I think this set is closed because it contains its limit points, because it only has one point.
Am i thinking about this correctly?
Hmm, that's an interesting question. I guess it would be closed because that's the only point in the set, and there's no option for an e-neighbourhood around it.
I think you are thinking about it correctly but that you are even asking this question makes me wonder. Can you explain your doubts further? What's the exact definition of a limit point?
thats what I thought too
If we wanted to put things on more definite footing, we could assume that it isn't closed. Then there is some point x1 such that for all E > 0 there is some x in our set such that d(x,x1) < E. However, since x = π in all cases, then the only such point is π, a contradiction.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
