Madeline
- 5
I was wondering what the name for "a" is in the following example.
The limit as x approaches a of (any function).
Madeline said:I was wondering what the name for "a" is in the following example.
jcsd said:"a" would be called "a point" as in "the limit of f at a point". Of course that's not a particularly special name.
Madeline said:Saying "point" almost implies that the limit is equal to the value of f at that point. At least that's what I think of. "A" isn't exactly a point, it's just a value in the domain.
jcsd said:There's reason for calling it a point, a limit requires that the domain (and the range) has more structure than a primitve concept of a set; the members of the mathematical structures we require are often called points. It may almost imply something to you, but it doesn't generally as it's standard usuage.
ps a minor quibble: "a" needn't lie in the domain of some function "f" for the limit of "f" at "a" to exist.
The value of "a" in an equation represents the coefficient or the number that is multiplied by the variable. It can also be thought of as the rate of change or slope.
The value of "a" determines the steepness or slope of the graph of an equation. If "a" is a positive number, the graph will have an upward slope, and if "a" is a negative number, the graph will have a downward slope.
Yes, "a" can be equal to 0. In this case, the variable is eliminated from the equation, and the resulting graph will be a straight line with no slope.
To solve for "a" in an equation, you would need to isolate it on one side of the equation by performing inverse operations. For example, if "a" is being added to both sides of the equation, you would subtract "a" from both sides to isolate it.
In the context of limits, "a" represents the value that a function is approaching as the input (x) approaches a certain value. This value can be used to determine the behavior of the function and if it has a limit at that point.
