Question about magnets and attraction
  • Thread starter Thread starter B4ssHunter
    Attraction Magnets
When a small magnet is placed at a considerable distance from a larger magnet, its attraction will depend on the orientation of its poles relative to the larger magnet's poles. The discussion highlights that attracted objects do not necessarily follow magnetic flux lines in the same way that electric fields operate, as magnetic forces act perpendicularly to these lines. The alignment of iron filings with magnetic flux lines is due to their nature as tiny magnetic dipoles, which behave similarly to current loops. Understanding these interactions requires a grasp of magnetization and its relationship to magnetic fields, often explored through advanced physics concepts. Experimentation with magnets is encouraged to gain practical insights into these principles.
B4ssHunter
what would happen if a small magnet was exactly placed by the middle of another larger magnet in a direction parallel to it and at a considerable distance ? will it be pulled to the south pole or to the north pole ?
or will it be pulled down the middle such that the north pole of the smaller magnet is on the south part of the bigger magnet and vice versa ?
what's a considerable distance ??
state something that is meaningful
how about trying it yourself? buy a couple of bar magnets and experiment with them
in the manner you have said and report back your findings :smile:
Dave
Dave
i apologize if my post was not meaningful enough , also here its very hard to find any place that sells magnets * other than fridge magnets *
basically what i am trying to find out is whether attracted objects follow flux lines or not .
i know iron fillings or magnets get lined up by the flux lines of strong magnets .
but do attracted objects follow those flux lines ? or do they get attracted and move in a straight line ?
if they don't follow flux lines then what is the difference between objects aligning themselves to the magnet and objects being attracted by the magnet ?
Objects don't follow flux lines in the same way as the electric field, because the magnetic force is perpendicular to these lines, whereas the electric force is tangent to these lines.
The magnetic force is felt by currents, and the force is perpendicular to the current direction AND the flux lines.
The alignment of magnetised iron filings parallel to the magnetic flux lines is due to a slightly more involved interaction, rather than a simple current, the iron filings are all tiny magnetic dipoles. Essentially a magnetic dipole is a tiny current loop, so the interaction is fundamentally the same, and it turns out that this current loop experiences a force which tends to make each individual filing align with the field.
Think of each one as a compass needle. There are no obvious currents in this needle, but it is still magnetised, which means the microscopic magnetic dipoles (i.e. current loops) are all pointing in the same direction.
To really understand the physics, you need to study the definition of magnetisation, and its relation to the magnetic field. Ideally this would be learned after you learn Maxwell's microscopic equations, which means vector calculus.
Until then, all I can give are hand-wavey explanations based on current loops which I imagine are impossibly hard to conceptualise.
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
