Mathematics, in the form of point-set topology, is important in describing concepts such as the continuum.
Thinking that the cardinality of the set of points is the only important issue is, however, is incorrect, as other posters have already mentioned. I'll give a specific example of why this is so. The cardinality of the set of points on an infinite line is the cardinality of the set of real numbers ##\mathbb{R}##, because there is a one-one correspondence (or if you prefer bijection) between the real numbers and points on an infinite line. The cardinality of the set of points on an infinite plane is the cardinality of the set of pairs of real numbers, ##\mathbb{R}^2##, because there is a one-one correspondence between pairs of real numbers and points on a plane.
But it turns out the cardinality of ##\mathbb{R}## equals the cardinality of ##\mathbb{R}^2##. Thus the cardinality of the number of points on a line are the same as the cardinality of the number of points on the plane. Loosely speacking, they have "the same number of points".
The resolution of this isn't trivial, and you'll have to read about point set topology to even get an inkling, it's not something you're likely to stumble over by yourself. It will take some serious study. This is especially true if you want a solid proof without any holes in it.
I can outline the end results, but not the formal proofs. While there is a bijection between ##\mathbb{R}## and ##\mathbb{R}^2##, so they have "the same number of points", there is NOT a homeomorphism from points on the line (which is a topological space), and points on the plane (which is a topological space). The topological space has added structure, that contains information about what points are "near" other points. The intuitive notion of "nearness" is more-or-less represented by the mathematical notion of "open balls".
Very very loosely speaking, then, what happens is that while we can map every point of the plane onto a single line, we can't do it in such a way that points that are "neighbors" in the plane are also "neighbors" on the line. Such mappings have the property that two points that are close to each other on the plane may be a long ways apart when we map them onto the line.
Using the same loose and imprecise language, mappings that preserve "neighborhood" are called homeomorphisms, and they are different from bijections (which are arbitrary 1:1 mappings that do not necessariliy preserve the "neighborhoods" structure.
You can try to read up on all the terms I mentioned, but you'll probably need a more formal approach to have it all make sense. You can try the math forums for better suggestions of where to read more if you want to study this area seriously.
There are plenty of other non-intuitive (but interesting) results from point-set topology, among the most famous is the Banach-Tarski "paradox".
<<link>>.
