Question about potential difference.
Potential difference (p.d.) is defined as the energy dissipated by a component in a circuit, such as a resistor, rather than the work done in moving a unit charge between two points. In contrast, electromotive force (emf) represents the work done by a source in moving a unit charge across a circuit. The distinction emphasizes that while emf is the energy supplied, p.d. reflects energy consumed. Understanding this difference is crucial for analyzing electrical circuits accurately. The clarification helps in grasping the roles of emf and p.d. in energy transfer within circuits.
yaseen shah
yesturday I read in a book that it is not correct to say that p.d is the work done in moving a unit charge between the points concerned i can not understand that point please explain that!
Emf is the work done by a Source in moving a unit charge across a circuit. P.D. is energy dissipated by some component in a circuit (e.g. resistor). Its like energy going in:emf and energy going out:pd.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
