Question about quantum erasure experiment
Ruven
I'm not a physicist, but I have a layman understanding of some aspects of Quantum Mechanics. I just watched a video explaining the experiment, where you put two differently polarized sheets behind each slit, but then erase the polarization with third polarizing sheet that's located between the slits and the measuring screen.
And I wondered, does it make a difference on how far away from the slits you put the third sheet? Like, does the pattern get wider or shorter depending on if you put the erasor closer to the slits or closer to the measuring screen?
Also, would the outcome change, if the erasor would be so close to the measuring screen, that the distance between them would be shorter than the wavelength of the "particle"?
Sorry to ask these very basic questions here, but I couldn't find a site where the experiment is not only explained, but where I could also find concrete answers to these questions.
No, as long as the sheet is large enough (otherwise there might be areas you don't cover).
Then you get nasty near-field effects of polarizers, and the answer depends on details of the setup.
I see. Thank you for the explanation. Much appreciated :)
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
