Question about speed and vehicles
  • Context: Undergrad
  • Thread starter Thread starter Sundown444
    Speed Vehicles
33 replies · 3K views
Sundown444 said:
I meant air and space.
That makes it easier, because in space we don't have to talk about drag from the air.
So the answer is no, faster motion is not harder to control. You can stop asking what factors make it harder, because it isn't harder.
Especially in space, get used to thinking of different frames of reference. An object moving fast in one frame is moving only slowly in a second frame, and not moving at all in a third frame. Yet the laws of physics remain the same in all frames. The difficulty of maneuvering a heavy object is the same in all frames. That is the kind of thinking (plus light speed) that eventually led Einstein to the special theory of relativity.
So the question should have been about mass, not speed, then? I could be wrong, but still...
Are you sure about the speed thing, though? I was also wondering about how it can be difficult to stop an object and changing direction. Momentum is how difficult something is to stop, and that is dependent on velocity. There is also friction and fluid friction (the latter is not used for space), especially the former being needed to come to a stop on the ground, and from what I have learned, kinetic energy quadruples with speed, which not only quadruples kinetic energy, but also stopping distance, if I recall correctly. Speaking of changing direction, centripetal acceleration is quadrupled with velocity, so the more velocity, the centripetal acceleration is quadrupled, and this, in terms of centripetal force (with mass added), more force is required to make centripetal acceleration happen.
If you keep changing the question I'm losing interest in answering. But one last time.
Remember the delta ##v## from post #6? Let's put it in terms of momentum which is ##mv##. Start at time 1 with momentum ##mv_1## then change to momentum ##mv_2##. The mass stays constant but velocity changes. Then the change in momentum is ##m(v_1-v_2)## If you let ##v_2## equal zero than means stopping. If you let ##v_2=-v_1## then we reversed direction.
The point is that the effort or work we need to do depends on the change in velocity, not the value of ##v_1##. So ##v_1## big means fast, ##v_1## small means slow. ##m(v_1-v_2)## is the same starting fast or slow. But stopping a fast object is more change in ##v## than for a slow object. But different observers moving at different speeds will disagree about what speed means stopped. So to say it observer independently, it is only the change that matters, not the initial velocity.Do you understand now?
Sorry. I didn't mean to change the question. I thought it was clear enough, but it wasn't. My bad.
And yeah, I understand. Thanks.
