Question about squaring velocity
  • Thread starter Thread starter ZenOne
    Velocity
In the equation v^2 = V0^2 + 2a(x), squaring the velocities V and V0 results in positive values regardless of their initial signs. The negative sign does not affect the outcome of the squared terms, as squaring any real number, including negative values, yields a positive result. Therefore, both V^2 and V0^2 will always be positive quantities. This confirms that the negative sign is irrelevant in the context of squaring these velocities. Understanding this principle is essential for correctly applying the equation in physics problems.
ZenOne
When using the equation v^2=V0^2 + 2a (x)...
If V or V0 is negative, does it become positive after squaring? (Basically, is the negative sign in the bracket or outside)?
Thanks in advance.
The velocities will be positive when squared.
V^2 and V0^2 will be positive quantities even when V or V0 is negative.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
