Question about surface area of faraday cage
The discussion revolves around the effectiveness of a Faraday cage in the context of reactive ion etching (RIE) of silicon. Participants explore how the size and surface area of the cage may influence its performance, particularly in relation to plasma flow and potential gradients during the etching process.
  • One participant questions whether the size and surface area of the Faraday cage impact its effectiveness, noting that factors like mesh size, material, and grounding are important.
  • Another participant asserts that size does not matter significantly, except for potentially very large cages, emphasizing that the quality of the seal is more critical.
  • A different viewpoint suggests that the cage could act as a microwave chamber if ions are inside, raising concerns about resonance and the cage acting as an antenna for high frequencies.
  • Another participant highlights the importance of limiting parasitic capacitance between electrodes and the shield to avoid disturbing the field geometry and plasma flow.
  • A participant clarifies that the cage is designed to shield a silicon wafer within an RIE etcher, and describes how the angled surface of the cage is intended to influence ion acceleration and etching direction.
  • Concerns are raised about the emission of photons from accelerating charges within the cage, specifically referencing Bremsstrahlung and its potential effects on the etching process.
  • One suggestion is made to reinject missing electrons before ions pass the cage to mitigate issues related to emitted photons.
Participants express differing opinions on the impact of the cage's size and surface area, with no consensus reached on whether these factors are significant. Multiple competing views remain regarding the effects of the cage on plasma flow and resonance issues.
Participants mention various assumptions about the operational conditions of the Faraday cage, such as its placement within the RIE etcher and the behavior of ions and electromagnetic emissions, which may influence their claims.
DKhosla
Hi,
I am making a faraday cage to be used in reactive ion etching of silicon. I was wondering if the size of the cage, or the surface area has any impact on it's effectiveness or how it works?
I know the size of the mesh and the material I use, as well as whether or not it is grounded all have an effect on it. I can't seem to find any information on the effect of size though.
No size does not matter, although I don't know about ridiculously large cages. There are big cages for sale and for example at CERN they routinely enclose big objects in tin foil or similar material. It's the quality of the seal that matters.
I'm going to disagree with Antti.
Since you seem to be talking about a manufacturing process I'm going to assume the ions are on the inside of the cage. In that case the cage could act as a microwave chamber. That could lead to problems. You will need to consider a way to prevent resonance.
More generally a cage can act as an antenna. High frequencies can slip through the holes. But I think you've considered these effects already.
I would think that in an RIE system you would need to limit parasitic capacitance between electrodes and shield in order to not disturb the geometry of the field. If the shield were too small (too close in proximity to the electrodes), it would disturb the geometry of the field and the plasma flow.
Thanks for your answers; I will definitely look into all of those things.
I think I should clarify that the cage is going inside an RIE etcher, to shield the silicon wafer. The cage is a triangular prism, and it is being used to do angled etching on the silicon wafer, so it is actually supposed to affect the flow of plasma.
(If the cage works, the potential gradient in the etching process will build up over the face of the cage and accelerate the ions perpendicular to the cage's surface. Since there is no field inside, the ions continue traveling in that direction. The surface of the cage is angled, so the ions hit the wafer at an angle.
Source: http://nano-optics.seas.harvard.edu/publications/Mike_freestanding.pdf )
Be aware that accelerating (and more importantly in your case, decelerating) charges emit photons. Basically the ions impacting the silicon will act as an antenna spewing radio waves all over the place -- inside your cage. This effect is called Bremsstrahlung.
One way to reduce this potential problem might be to reinject the missing electrons just before passing the cage. Of course you might want the extra energy of the photons to break substrate molecular bonds.
  • · Replies 35 ·
9K
