Question about the size of a set.
  • Thread starter Thread starter cragar
    Set
The discussion centers on the properties of unions of uncountable sets. An uncountable union of uncountable sets will also be uncountable, but its exact cardinality, such as whether it equals 2^{\aleph_1}, depends on the cardinality of the individual sets and whether they are disjoint. The example provided illustrates that if there are 2^{\aleph_0} disjoint sets, each with 2^{\aleph_0} elements, the resulting union will have 2^{\aleph_0} elements. The conversation also touches on the challenge of proving these properties, particularly for uncountable sets, and suggests consulting set theory literature for further clarification. Understanding these concepts is crucial for grasping advanced set theory.
cragar
If I had an uncountable number of sets, and each of these sets had an uncountable number of elements. Then I took the union of all of these sets would the number of elements be uncountable or would it be 2^{\aleph_1}
Mathematics news on Phys.org
First of all, 2^{\aleph_1} IS uncountable.
Second, you failed to mention the cardinality of your number of sets and the cardinality of the sets in question. The answer depends crucially on that.
Also, the answer depends on whether the sets are disjoint or not.
Right now, the only thing we can say is: if you have an uncountable union of uncountable sets, then this union will be an uncountable set. It might or might not be 2^{\aleph_1}.
I have 2^{\aleph_0} sets. And they each have 2^{\aleph_0} elements. And all the sets are disjoint. The sets share no common elements.
Then you'll end up with 2^{\aleph_0} elements.
ok thanks for your answer. I am trying to think how you would prove that. Could you give me a hint on how to prove that. I mean if I had a countable number of sets I could just map all the elements in the first set to all the numbers between 0 and 1 and then for the next set map them to 1 to 2. I am not sure how you would do it with an uncountable number of sets.
Any good set theory book will prove this.
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
