Question about the stretch of rope
  • Context: Undergrad
  • Thread starter Thread starter aditya ver.2.0
    Rope Stretch
The discussion revolves around a physics problem involving a rope of length L1, which is stretched by two forces F1 and F2 exerted equally by points A and B. When a metallic block of mass M1 is tied at the center, it causes a depression D1 in the rope. The participants emphasize the need for a structured approach to solving the problem, including understanding the forces acting on the mass and the resulting tension in the rope. The consensus is that this question is more suited for a homework forum, where guidance can be provided in a more educational context.
  • Understanding of Newton's laws of motion
  • Basic principles of tension in ropes
  • Knowledge of forces acting on a mass
  • Familiarity with the concept of depression in a stretched rope
  • Study the principles of tension and equilibrium in physics
  • Learn how to calculate forces acting on objects in static and dynamic scenarios
  • Explore the effects of mass on tension in ropes and cables
  • Review problem-solving techniques for physics homework questions
Students studying physics, particularly those tackling mechanics and forces, as well as educators looking for examples of structured problem-solving in physics coursework.
aditya ver.2.0
A rope of length L1 is stretched from both ends by A and B ( both are exerting equal amount of force F1 and F2, where F1=F2)to keep it rigid. Just then C ties a metallic block of mass M1 at the center of the rope.Due to the weight of the block, the rope hangs down and creates a depression of D1 meters.
Q.1 At what rate (in Newton) should A and B pull the string so that the depression starts to reduce by H1 m/sec, in the presence of the metallic block?
Q.2 At what rate (or differential rate) should both the ends of the rope move, so that the depression reduces by H1 m/sec?
Hi. This looks like a Homework / Coursework question and it should probably be in that forum.
As we don't just answer such questions 'for free' (PF is far too mean to spoon feed people!), we need to see what you, yourself, have done towards answering the question.
For instance, what are the forces acting on the Mass M1 and what would be the tension in the rope?
Sorry Sir, I am beginner in this section. Urgently want to learn how to solve such question. Please...
Sophie is correct. This question belongs in the homework forums. Please repost it there and use the template provided when you click on New Post. Note that PF is not here to teach you how to solve such questions from scratch. If you have no idea where to begin then you should seek help from your teacher or someone in your class.
12K
12K
