Question concerning convolution
  • Thread starter Thread starter peripatein
    Convolution
The discussion revolves around the concept of convolution, specifically focusing on the integration boundaries and overlap of functions during the convolution process. Participants explore the implications of shifting functions and the resulting areas of overlap, with references to piecewise functions and graphical representations.
  • Some participants express confusion regarding the integration boundaries for convolution, particularly for the range 1
  • Others propose that the convolution consists of three segments: an increasing linear function, a constant slope, and a decreasing linear function, with specific piecewise definitions.
  • A participant clarifies that the integration boundaries for the first range are not fully understood, and they reference a solution provided by the professor.
  • Some participants suggest that the overlap begins at tau=1 when the function is shifted, while others argue that there is no overlap for 1
  • There are discussions about the distinction between time (t) and the shift amount (tau), with some participants emphasizing the importance of understanding this difference for convolution.
  • One participant mentions that the solution is based on the area contained after shifting, rather than the overlap at any specific time t.
  • Some participants express frustration with the clarity of the diagrams and notation used in the discussion, indicating that it contributes to the confusion.
  • There is a mention of cross-correlation concepts as a way to better understand convolution, noting the differences in shifting direction.
Participants do not reach a consensus on the integration boundaries and overlap for the specified range. Multiple competing views remain regarding the interpretation of the diagrams and the relationship between t and tau.
Participants highlight limitations in the clarity of diagrams and notation, which may contribute to misunderstandings about the convolution process and the integration boundaries.
peripatein
Hi,
I have a question concerning convolution. I don't quite understand the boundaries of the integration in the attachment. The way I see it, the areas do not overlap at all for 1<t<3. You might say that they do overlap at 0, but that is usually not considered an overlap. Even if they were overlapping, why would the upper boundary be t-1 for that range?
I'm confused by this. The convolution will be a three part convolution the first section being an increasing linear, and then it will be a constant slope, and then it will become a decreasing linear line.
The piecewise functions will be something like:
0 -> -inf<t<0
Ax -> 0<t<2
B -> 2<t<3
-Cx -> 3<t<5
unless you are looking at the tau as negative shift then it's all backwards and I don't understand your question
First, let me clarify that I was merely referring to the first range. That is, this is not the complete answer. Please see attachment for the rest. I couldn't even understand the integration boundaries for the first range, which is why I only attached that part of the solution. The solution was provided by the professor, so it is not likely that it is wrong.
Would you please explain this to me?
I would agree completely with that solution.
Are you asking about why the solution is such on one of the ranges? you are asking why the first range is the way it is? Are you confused by the slope or the range?
Keep in mind that the x-values for the solution DO NOT correspond to the x-values of the functions. The x-values of the convolution refer to the AMOUNT of times the function has been shifted.
I don't quite understand the boundaries of the integration. Let's look at the first range (1<t<3). The way I see it, the areas do not overlap at all for 1<t<3. You might say that they do overlap at 0, but that is usually not considered an overlap. Even if they were overlapping, why would the upper boundary be t-1 for that range?
It's hard to discuss a visual convolution over text, but I'll try.
So in the picture where are you do is reflect the wider rectangle across the Y-axis is t = 0 (TAU not to be mixed up with T: time)
These images are confusing for a first time convolver. They barely differentiate between time and tau (shift amount)
so when you move the blue function to the right one unit, that is tau = 1. Between tau = 0 and tau = 1 the functions are overlapping. This means that exactly after tau = 0 there will be an increasing function in the convolution.
Now increase the tau again to tau = 2. wait.
I think I see what you are saying. You are saying that the convolution should have an increasing value on the interval from tau = [0,1]? because now that I really study that solution, I don't think it's correct.
All I was saying was that I didn't quite understand why there would be any overlapping between 1 and 3. By the way the rectangles are drawn in the attachment, they do not seem to overlap at all. If you could explain to me why the integration for that range would be between 0 and t-1, perhaps I could pick it up from there on my own.
you are asking a vague question, are you asking is there an overlap between T=[1,3] or Tau=[1,3]?
Oh wow I was misunderstanding the question, that answer is correct okay now I see it. I didn't realize that the first frame of the second thumbnail was an already shifted function.
when the function is not shifted, there is no overlap. This is why the function solution is 0 from tau=[0,1]. then once you shift the blue rectangle right one unit, there is initial overlap at tau=1. so the function solution begins to increase after tau=1. as tau (shifting) keeps increasing there is more and more overlap. This happens until tau = 3 then the overlap remains the same for tau=4. I'm trying to grasp your question here it's a bit hard to get what you're asking.
keep in mind that you are comparing always the reflected blue function- NOT the blue function itself
I am sorry, but I still don't quite understand why based on the diagram there would be any overlap between the two rectangles for 1<t<3. Doesn't the diagram show that they intersect only at 0?
you are mistaking t and tau. There is definitely no overlap from 1<t<3 there is definitely overlap from 1<tau<3
do you understand the difference I am trying to make? the solution isn't the overlap at any time, t. The solution is the amount of area contained after shifting any distance, Tau.
Those diagrams are absolutely terrible with notation, I understand your confusion.
And what is the relation between t and tau?
the teacher differentiates between T and Tau by using T and T' which is not a very clear distinction. T is simply the function value at any time. T is in your standard time domain, that we are all so comfortable using. now TAU is the magical convolution x-axis. tau is a measure of how far you have shifted a function. f(t-TAU) is a shift in TIME by the amount TAU. does this make sense? so the convolution is in "tau space"- it isn't a time representation of anything, it is simply a representation of the overlap of the functions (in time) at different shifting amounts.
it's a way to get some weird conceptual value of the commonality of two functions at every point in both functions at every shifting value.
I didn't understand convolution that well until I saw (cross)correlation concepts.
http://en.wikipedia.org/wiki/Cross_correlation
the only difference is your shifting goes in the opposite direction in correlation functions.
Basically if you have two strings of numbers (maybe different slightly) that are phase shifted, when you correlate them, and they have a huge peak in the correlation, the strings of numbers are strongly correlated. Because at some point, there is a lot of overlap in the functions. This is a fairly common communications concept.
please don't yell at me for leaving out the integration of tau and being solely in time space for the solution. When you are doing this graphical convolution kinda stuff, you are considering shifts by tau units.
Let us concentrate on the first range only for now. I still don't understand why for 1<tau<3 there would be an overlap based on the diagram. If I came to understand that, I would understand the entirety.
when tau = 1, you shift the function to the right one unit. This is where overlap begins. when 1<tau<2 the functions are overlapping, do you see this?
Right, and when you shift it three units it should reach 2. Hence, why shouldn't the integration be between 0 and t? Why is it between 0 and t-1?
