Question on integral notation (dt, dx, etc.)
  • Context: Undergrad
  • Thread starter Thread starter hulgy
    Dx Integral Notation
7 replies · 3K views
hulgy
Say the limit of the integral is from 0 to t and the integral is ended with a dt. Is this okay?
Generally, all the integrals I see with a variable limit end with a d-letter that is not the same as the variable in the limit. ie: limit is from 0 to t, ends with du
Welcome to PF!
Hi hulgy! Welcome to PF! :smile:
Noooo …
If you have an ∫ f(t) dt, that has to be between limits of t …
t can't depend on itself. :wink:
(once you've integrated over a variable like t, that variable should disappear, not come back to haunt you!)
Noooo …
Hmmm... what if t stood for a value like 1<t<3 which you would have to place into the 0 to t limit (this would technically eliminate the variable...right?). Would the integral as a whole still be wrong then?
Not following you :confused:
can you write the integral out in full? :smile:
(you can write integrals like this: [noparse]∫ab[/noparse] … ∫ab :wink:)
0t (50)dt for 1<t<3
hulgy said:
0t (50)dt for 1<t<3
hmm …
If you mean ∫0s (50)dt for 1<s<3, then that's fine.
But no, you can't use t for two different things.
That is a bit of abuse of notation -- not that you won't see such abuse.
The dt inside the integral is a dummy variable. It might as well be tau, or x, or anything. It has nothing to do with the upper limit of the integration.
This is at best confusing:
[tex]f(t) = \int_0^t \cos t\, dt[/tex]
What is [itex]df/dt[/itex]?
If the above integral is expressed as
[tex]f(t) = \int_0^t \cos \tau\,d\tau[/tex]
then it is pretty clear that [itex]f(t)=\sin t[/itex] and that [itex]df/dt = \cos t[/itex].
Occasionally you will run across things like
[tex]f(t) = \int_0^t \cos (t-\tau)\,d\tau[/tex]
The t inside the above integral is not a dummy variable. As far as the integration is concerned that t inside the integral is a constant.
I guess I'm going to get points off for notation on my AP calc test then. Well thanks for all the help, really cleared things up.
