Question on Waves and Interference
The discussion revolves around calculating frequencies of sound waves produced by two in-phase loudspeakers that cause interference at a listener's position. The user is trying to determine the frequencies at which the listener hears minimum and maximum signals, using equations related to path length differences and phase differences. They have successfully derived some equations but are struggling with the calculations for minimum frequencies, specifically the wavelength and how it relates to the path length difference. The conversation highlights the importance of understanding constructive and destructive interference in wave behavior, as well as the need for accurate calculations to find the correct frequencies. Overall, the user is seeking clarification and assistance in resolving their confusion regarding the calculations.
yanimated
Please help! I've been stuck on this for a very very long time :confused: .
Two loudspeakers, separated by a distance of d1 = 1.60 m, are in phase. Assume the amplitudes of the sound from the speakers are approximately the same at the position of a listener, who is d2 = 3.90 m directly in front of one of the speakers.
See Diagram: http://www.webassign.net/hrw/18_32alt.gif"
(a) For what frequencies in the audible range (20-20,000 Hz) does the listener hear a minimum signal? (Give the lowest, second lowest and highest possible frequencies in the audible range.)
I JUST FIGURED THIS ONE OUT:(b) For what frequencies is the signal a maximum? (Give the lowest, second lowest and highest possible frequencies in the audible range.)KEY: d = delta, f = frequency, v = velocity of air, dL = path length difference, m = nodes I assume?
If not, what's m in the equation (seen below)?
dL = (m+.5)(v/f)
v = 343 m/s
d3 = squareroot(1.6^2 + 3.9^2) = 4.22 m
I was able to derive this: f = (m+.5)(v/dL) from the dL equation given.
Phase difference at the person is = 2pi(d3-d2)/lamda
For minimum intensity at the listener, phasediff = (2m+1)pi
and lamda = 2pi(d3-d2)/phasediff
freq = v/lamda = [(2m+1)v]/[2(d3-d2)]
and that leaves me with (2m+1)[v/(2(d3-d2))]
[v/(2(d3-d2))] = frequency that I get
For me, it's 543.67Hz.
And 20000Hz/543.67Hz = 37.3
2m+1 = 37
So m needs to be between 1 and 18 I believe...
I figured out part b.:smile:
lamda = (1/n)(d3-d2)
so f = v/lamda = nv/(d3-d2) = n(1088.89Hz)
20,000Hz/1088.89Hz = 18.37
n = 1 through 18
Plug in 1, 2, and 18 for frequencies...
But I'm still wrong for part a...:mad: :frown: :bugeye: :devil: :cry: :zzz:
Now here is a prof I like right away. One of my favorite ugrad courses "physics of hi-fi"
The path length difference between the right and left speakers is
sqrt(d2^2+d1^2)-d2=Diff. When that difference is a complete wavelength, the two add to produce a maxima, when it is a 1/2 wavelength, you get destructive interference. So the first maxima would occur at a wavelength of .32m and integer multiples of this frequency. Help at all?
M by the way is the wave number, it starts at zero to capture the first minima, when it is 1, you get the first max
You lost me in the last sentence. I understand your response until the sentence ending with "destructive interference." How did you come up with .32m for the wavelength?
I played around a bit more and here's what I've figured out since posting. Also added this to the original post:
2m+1 = 37
So m needs to be between 1 and 18 I believe?
I'm pretty sure I'm close...but somehow the answers I'm getting are still incorrect.
the .32 is from your math--hypotenuse minus D2. Thats the path length difference, so for constructive interference to occur, the wavelength is equal to that distance or some integer multiple numbers of wavelengths. Forget the profs eqn for a minute as that doesn't add to really understanding the problem. Think about the waves from the two speakers. They can completely add, cancel or mostly do a bit of one or the other depending on their arrival times. so the lowest frequency where they cancel, the diff in pathlengths=1 wavelength=C/f. Help at all?
