Question regarding inelastic collisions
Inelastic collisions result in a range of kinetic energy values post-collision, influenced by how inelastic the collision is. The maximum final kinetic energy can equal the initial kinetic energy, occurring only in perfectly elastic collisions. Conversely, the minimum occurs when colliding particles stick together, yielding zero kinetic energy in cases of equal masses with opposite velocities. The relationship between kinetic energy and momentum is clarified, showing that the kinetic energy can be expressed as half the total momentum squared divided by total mass. Understanding these dynamics is crucial for analyzing inelastic collisions accurately.
Vector1962
Concerning inelastic collisions: Is it true the kinetic energy after the collision is equal to 1/2 the total momentum?
CORRECTION:
Concerning inelastic collisions: Is it true the kinetic energy after the collision is equal to 1/2 the total momentum squared divide by total mass?
The kinetic energy has a range of values after the collision depending on just how inelastic the collision is.
The largest value the final kinetic energy could have would be equal to the initial kinetic energy, but this only happens in the limit that the collision becomes elastic.
The smallest value the final kinetic energy could have would be the kinetic energy if after the collision the particles stick together. This value depends on the ratio of the two masses, and the ratio of the two initial velocities. It is not simply half the initial kinetic energy (though I'd have to work it out to see if that's indeed the smallest possible value over all initial masses and velocities).
Two equal masses with equal and opposite velocities colliding and sticking together will yield zero kinetic energy.
(Think head-on SPLAT!).
Likes jfizzix
point taken!
Vector1962 said:
CORRECTION:
In a perfectly inelastic collision, all the participants will stick together after the collision. The resulting momentum will be ##m_{tot}v_{cm}##. Yes, the resulting kinetic energy is ##\frac{1}{2}m_{tot}{v_{cm}}^2 = \frac{1}{2}\frac{(m_{tot}v_{cm})^2}{m_{tot}}##
excellent. thanks for all the reply's.
