Questions about movement of a permanent magnet inside of solenoid.
The discussion revolves around the movement of a permanent magnet inside a solenoid with applied DC current. Participants explore the underlying principles and behaviors observed during experiments involving the interaction between the magnet and the solenoid.
  • One participant describes experiments where a cylindrical permanent magnet moves to the center of a solenoid when current is applied, and notes that reversing the current changes the magnet's direction of movement.
  • The same participant conjectures that the magnet's movement is influenced by the interaction of magnetic flux lines from both the magnet and the solenoid, suggesting an equilibrium is reached at the center.
  • Another participant suggests switching off the electromagnet just before the magnet reaches the center and then reversing the polarity, implying a method to control the magnet's movement.
  • A third participant references Fleming's Left Hand rule as a potential explanation for the observed movement of the magnet towards the center of the solenoid.
  • One participant expresses difficulty in applying the equation F = I x B, questioning the vector orientations involved in the interaction.
Participants present multiple viewpoints and hypotheses regarding the behavior of the magnet in the solenoid, with no consensus reached on the underlying mechanisms or the application of the relevant equations.
Participants express uncertainty about the application of theoretical concepts to their experimental observations, and there are unresolved questions regarding the vector relationships in the equation F = I x B.
jalbers
I have been doing some experimenting with a relatively short cylindrical permanent magnet and a solenoid with DC current applied. I would like an explanation as to why these two things happen. The OD of the cylindrical magnet is just a little bit smaller then the ID of the solenoid.
Placing the magnet near the left end of the solenoid and applying current will cause the magnet to move to the right and stop at the center of the solenoid. Manually moving the magnet back slightly to the left and reversing current will cause the magnet to move to the left.
Placing the magnet near the left end of the solenoid and applying current will cause the magnet to move to the right and stop at the center of the solenoid. Manually moving the magnet slightly to the right and reversing current will cause the magnet to continue moving to the right.
Before doing these experiments my conjecture was that the magnet placed at the end of the solenoid would pass completely through the solenoid. My thinking was that movement of the magnet would be caused by the flux lines of the magnet and the solenoid being in different directions all the way through the inside of the solenoid.
My next though is that the flux lines moving through the center of the solenoid in the opposite direction as the magnets flux lines bulge out around the magnet kind of like a snake swallowing something. Somehow the magnet finds equilibrium in the center of the solenoid.
I have been watching the MIT open course physics lectures http://openlearning.wordpress.com/2007/12/19/the-walter-lewin-lectures and understand some of the concepts but still don't know how to apply them to this situation.
Any help would be greatly appreciated. Thank you.
Well, you could switch-off the electromagnet just before the magnet reaches the middle, then switch the electromagnet back on with reverse polarity after the magnet passes the middle.
Do you know about Fleming's Left Hand rule? Thats where your answer lies as to why the magnet moves to the center of the solenoid.
I know that F = I x B but when I try to apply it I don't get anywhere. (I) is a vector tangent to a point on the solonoid. (B) is a vector parallel to the central axes of the solonoid. So I x B or (F) would be a vector perpendicular to the central axes of the solonoid ?
