Questions concerning mobile audio: Capacitor to filter tweeters
1 replies · 2K views
LightFantastic
https://www.parts-express.com/dayton-audio-nd25fn-4-1-neo-silk-dome-tweeter-element-4-ohm--275-053
https://www.parts-express.com/cat/capacitors/68
Tried replacing the OEM speakers in my vehicle with a set of aftermarkets ...without exchanging the OEM head unit. Terrible idea, and I knew better. As far as efficiency/sensitivity goes, OEM blows aftermarket right out of the water. So I stuck my OEM speakers back in.
I can handle the muddiness out of my midwoofers, but the OEM tweeters are fatiguing. It is my understanding that tweeters don't need a lot of power, so I am interested in replacing them. They are wired in parallel with my front midwoofers, and filtered with a capacitor. They need to go high in my doors off axis, and fitted in a rather tight location. There's only a handful of 4 ohm tweets from parts express that will fit the physical constraints.
I'm not sure how to choose the correct cap value or the type of cap. Ceramic, polypropylene, electrolytic..?
Desired tweeters are linked at the top of the page.
Guess I'm just worried that the tweeters won't be able to keep up with the mids. Couldn't find the sensitivity rating on the daytons, but I assume they're much lower than oem ...which isn't a good thing.
8uF would be a conservative value so you are less likely to blow them out with too much mid-range power. If you need more midrange going to 16uF (or possibly 20uF) will boost the mids.
Remember that you Must use non-polarized (non-polar) capacitors. Ordinary electrolytics act like they have an internal diode across them and will block the bass in only one polarity of the waveform; they will let half the bass thru to smoke the tweeters.
The tweeters you have chosen are good down to 2.5kHz and have an impedance of 4 Ohms. A 8Uf cap will cut the power to 1/4 at 5kHz with further cuts as the frequency decreases. A 16uF cap extends down to 2.5kHz (the tweeter rating), and 20uF will get you down to 2kHz.
