sarveshkumarv
- 6
Why microwave frequencies are more affected due to rain? How does water actually affect microwaves?And lower frequencies have more diffraction.Why is it so?
One can analyse single-slit diffraction in terms of the Heisenberg Uncertainty principle. A photon passing through a slit has a positional uncertainty, dx equal to the width of the slit, d. The uncertainty in momentum component across the width of the slit, dp_x must obey the HUP, i.e.;sarveshkumarv said:And lower frequencies have more diffraction.Why is it so?
No a narrow beam is one that doesn't spread out as much. Think of a narrow beam of light from a flashlight,(CROSS POST)
is it correct to term a narrow beam as a beam with small wavelength?
Also what is the mathematical relationship between
1.)attenuation and frequency,
2.)power and frequency( power transmitted and power consumed) and
3.) transmitted power and distance
In general yes but I suspect fading might be used for when a signal changes in strength due to changing conditions and attenuation is used for a fixed decrese in signal strength.sarveshkumarv said:What is the difference between attenuation and fading?Do they mean the same?
Loren Booda said:Do microwaves primarily interact with the nuclei, hydrogen bond or other valences of H2O?
As a rough guide:Loren Booda said:Do microwaves primarily interact with the nuclei, hydrogen bond or other valences of H2O?
A handy rule of thumb!As a rough guide:
X-ray = interact with nuclei
UV-visible = electron levels
IR = molecular bonds
MicroWave-Radio = rotation of molecule
