Quetions of body under collison
  • Thread starter Thread starter manal950
    Body Collison
The discussion focuses on calculating the velocities and heights of two colliding bodies using conservation of momentum and energy equations. Initial velocities and masses are provided, leading to the derivation of final velocities (V1 and V2) after the collision. The calculations involve solving simultaneous equations to find these unknowns, with corrections made along the way to ensure accuracy. The final heights calculated for different coefficients of restitution (e) are approximately 1.7 m when e = 1 and 1.4 m when e = 0.8. The method and equations used are confirmed to be correct, although some initial values were slightly off.
manal950
Hi all
http://store2.up-00.com/June12/pG127901.jpg
V^2 = u^2 + 2as
V = 8.85 m/s which will be intial veloctiy befor hits the second body
Bu using
e(u1 - u2 )=V2 -V1
m1u1 +m2u2 =m1v1+m2v2
for the body which is 20 N
mass 20.3
u1 = 8.86 0m/s
V1 after collision = 0 m/s
for the second body which is 40 N
mass = 4.077
u2 = 0
v2 we will find final velocity after collion
2.03 X 8.86 + 4.077 X 0 = 2.03X(0) + 4.077V2
v1 after the collision is not 0, this is because the objects have different masses.
But since u2 is 0, you can solve for v1 using:
V = (m1-m2)u/(m1 + m2)
After solving for v, using that for kinetic energy and set that equal to potential energy.
you mean by ""using that for kinetic energy and set that equal to potential energy""
this equation
and is the final answer for height
1.78 and 1.44 m
Because we have 2 unknown V1 and V2 I will find it by this two equation ...
m1u1 +m2u2 = m1v1 + m2V2
2.03X8.8+4.077(0) = 2.03(v1)+4.077V2
17.6204 = 2.03V1 + 4.077V2 ====== fist equation (1)
e(u1-u2) = (V2 - V1)
0.8(8.86 - 0 ) V2 - V 1
V2 = 7.088 + V 1 this second equation (2)
so I will make V2 in first equation
17.6204 = 2.03V1 + 4.077(7.088 + V1 )
17.6204 = 2.03V1 + 28.89+4.077V1
V1 = -1.84m/s
Now I will findV2
17.06204 = 2.03(-1.84) + 4.077V2
21.6551 = 4.077V2
V2 = 5.24 m/s
so is that correct or not ??
this equation
1.78 and 1.44 m
I actually gave you the wrong equation, my mistake.
The correct equation is:
v2 = (2m1 u1)/(m1+m2)
Solve for v2, then use that value for kinetic energy and set that equal to potential energy, which is mgh.
see my post number 4
V1 = -1.84m/s
Now I will findV2
21.6551 = 4.077V2
V2 = 5.24 m/s
Yes, the method is correct, but the velocity is off by a bit.
2.038735X8.85889+4.07747(0) = 2.038735(v1)+4.07747V2
18.0609 = 2.038735(v1) + 4.07747V2 ====== first equation (1)
0.8(8.85889 - 0 ) V2 - V 1
V2 = 7.087112 + V 1 this second equation (2)
18.0609 = 2.038735(v1) + 4.07747(7.087112 + V 1)
18.0609 = 2.038735(v1) + 28.89748 + 4.07747V1
18.0609 - 28.89748 = 2.038735(v1) + 4.07747V1
-10.83658 = 6.116205 V1
V1 = -1.77178 m/s
Now I will findV2
V2 = 7.087112 + (-1.77178)
V2 = 5.3153 m/s
----------- now for the e = 1 I will get velocity V2 -----------------
1(8.85889 - 0 ) =V2 - V1
V2 = 8.85889 + V 1
I will make V2 in 1
18.0609 = 2.038735(v1) + 4.07747(8.85889 + V 1)
18.0609 - 36.12185 = 6.116205V1
V1 = -2.9529 m/s
V2 = 8.85889 + (-2.9529)
v2 = 5.9059 m/s Now finding the height :
when e = 1
1/2mv2 = mhg
0.5(2.03873)(5.9059)^2 = 2.03873 X 9.81 X h
h = 1.7 m
when e = 0.8
1/2mv2 = mgh
0.5(2.03873)(5.3153)^2 = (2.03873)gh
m = 1.4 m
