Solving for Inverse Function of f(x)= x+1 / x
  • Thread starter Larrytsai
  • Tags
    Algebra
In summary: However, if, as you appear to be saying, the problem really is y= x+ 1/x, becoming x= y+ 1/y, then multiplying both sides by y gives you xy= y2+ 1. That you would write as the quadratic equation y2- xy+ 1= 0 and solve using the quadratic formula with a= 1, b= -x, c=1. Notice that you will have a "\pm" which means that the original function was not "one to one" and so does not have a true inverse.
Larrytsai
228
k this is a function and i have to find the inversed
f(x)= x+1 / x
attempt: x= y + 1 / y
multiply both sides by 'y'
x(y)= y + 1
subtract both sides by y
x(y) -y=1
divide 'x'
im lost from here help please:D
You must improve your notation. You seem to mean, f(x) = (x +1)/y from which you may like to
find an inverse such as x = (y + 1)/x and the rest is simple algebraic steps.
umm my book saids y= x+1/x
If that is what your book said, then the exchange will be from y = x + 1/x
to x = y + 1/y
I made a variable writing error in my first response.
to x = y + 1/y
yea that's i did but what i don't know is where i went wrong in my algebra
... just to continue, your next step would be to multiply both sides by 'y'.
k this is what i got so far x(y)= y-1
should i move the y to the other side or the '-1'?
No. That step is wrong. I obtained an xy term like you did, but I see no way to obtain a clear y as a function of x. Either I have become deficient in some of my inverse function skills, or your original function cannot be converted to an inverse according to "Intermediate Algebra" methods. Certainly someone will advise us. Maybe a different coordinate system? Polar?
f(x)= x+1 / x
x(y)= y + 1
If this were y= (x+1)/x, becoming x= (y+1)/y, then you would have xy= y+ 1.
x(y) -y=1
divide 'x'
First factor out "y": y(x- 1)= 1 and then divide by x-1.
However, if, as you appear to be saying, the problem really is y= x+ 1/x, becoming x= y+ 1/y, then multiplying both sides by y gives you xy= y2+ 1. That you would write as the quadratic equation y2- xy+ 1= 0 and solve using the quadratic formula with a= 1, b= -x, c=1. Notice that you will have a "[itex]\pm[/itex]" which means that the original function was not "one to one" and so does not have a true inverse.
Related to Solving for Inverse Function of f(x)= x+1 / x
1. What is an inverse function?
An inverse function is a function that undoes the action of another function. It can be thought of as the "reverse" of the original function, and when applied to the result of the original function, it returns the original input value.
2. How do you solve for the inverse function of a given function?
To solve for the inverse function of a given function, switch the x and y variables, and then solve for y. This will give you the inverse function in terms of x. For example, to find the inverse function of f(x) = x+1/x, you would write it as y = x+1/x and then solve for x, resulting in the inverse function g(x) = (x+1)/(y-1).
3. What is the domain and range of an inverse function?
The domain and range of an inverse function are switched from the original function. This means that the domain of the inverse function is the range of the original function, and vice versa. In the case of f(x) = x+1/x, the domain is all real numbers except for 0, and the range is also all real numbers except for 0.
4. How can you check if a function and its inverse are correct?
One way to check if a function and its inverse are correct is to use the composition of functions method. This involves plugging the original function into the inverse function and vice versa, and if the resulting functions are equal, then the inverse is correct. In the case of f(x) = x+1/x and its inverse g(x) = (x+1)/(y-1), the composition of functions would be f(g(x)) = (x+1)/(x+1) and g(f(x)) = (x+1)/((x+1)/x), both resulting in x, indicating that the inverse is correct.
5. Why is it important to find the inverse of a function?
Finding the inverse of a function is important because it allows us to "undo" the effects of a function and solve for the original input value. This is useful in many real-world applications, such as finding the original price of a discounted item or calculating the initial speed of an object given its acceleration and time. Inverse functions also have many mathematical applications, such as in solving equations and understanding the behavior of functions.
  • Precalculus Mathematics Homework Help
