Quick order preserving map question
  • Thread starter Thread starter EV33
    Map
EV33
Let X and Y be ordered sets in the order topology.
I want to show that a function f:X→Y is injective. We are given that f is surjective and preserves order.
Definition of an order preserving map:
If x≤y implies f(x)≤f(y)
So if we assume that it is not injective then we are assuming that f(x)=f(y) and x\neqy.
Then either x>y or y<x. Assuming both, would clearly be a contradiction since it can only be one or the other in an ordered set.
Now I need to show that x>y raises a contradiction and similarly x<y also raises a contradiction.
My main question here is if x<y is it a contradiction if f(x)=f(y)?
It seems like if order is preserved then if x<y then f(x)<f(y)
but by the definition, it appears that if x<y then f(x)<f(y) or f(x)=f(y).
Thank you for your time.
Yes, you do. Use the fact that f is an order preserving map. If x< y, what can you say about f(x) and f(y)?
What, exactly, is that definition? "if x< y the f(x)\le f(y)?
Thank you, HallsofIvy. Actually, what you just said is exactly what my question is. My question was probably a little convoluted so let me restate it.
I was trying to ask, if we have a function that preserves order
and x<y
1) do we conclude that f(x)<f(y)
2)or do we conclude that f(x)≤f(y)
The definition makes me think it is the second option but if I didn't have the definition I would have thought it was the first.
Just to make it more clear what I am asking. If order is preserved does it mean
if x<y implies f(x)<f(y)
if x>y implies f(x)>f(y)
if x=y imples f(x)=f(y)
if x≤y imples f(x)≤f(y)
if x≥y imples f(x)≥f(y)
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
